rsanoa
Joined: 10 Jan 2006 Posts: 71 Location: Bell Buckle,TN
Posted: Sun May 28, 2006 8:34 am Post subject: Pennzoil 2 stroke aircooled oil |
Help, help,
"Pennzoil 2 stroke air cooled engine oil" which I have always used has disappeared in this area. Is it off the market every where? If so what are most of you finding as a good substitute. They are pushing their 2 stroke outboard engine oil which is partially synthetic. Any one have any experience with it?
Ray
UltraStar
TN Do no archive
Get on board. You're invited to try the new Yahoo! Mail Beta.
_________________ Ray S.Anderson |
herbgh
Posted: Sun May 28, 2006 8:55 am Post subject: Pennzoil 2 stroke aircooled oil |
Ray
Zip on over to your local Advanced Auto store and order it.. They will
use your order to create a stocking status for that store.. Did that in
Lafayette Tenn .
There is a distributor in Goodlettsville,Tenn. Friends claim to buy
it by the case there.. Herb
On Sun, 28 May 2006 09:32:29 -0700 (PDT) ray anderson <rsanoa(at)yahoo.com>
writes:
Help, help,
Ray
UltraStar
TN Do no archive
HShack(at)aol.com Guest
Posted: Sun May 28, 2006 8:57 am Post subject: Pennzoil 2 stroke aircooled oil |
In a message dated 5/28/2006 12:34:28 PM Eastern Standard Time,
rsanoa(at)yahoo.com writes:
I started with Penn. 2 stroke aircooled, went to their outboard oil, then to
AV-2. All of it worked well for me, can't recommend one over the other.
Howard Shackleford
FS II
SC
Richard Pike
Posted: Sun May 28, 2006 9:59 am Post subject: Pennzoil 2 stroke aircooled oil |
I have had good success since 1983 using Phillips Injex two stroke oil.
Switched to Pennzoil for one season to try it out, the only difference I
could see was that the oily mung on the tail feathers was nastier. Went
back to Injex. I call the local distributor and they drop off a case of
12 quarts at the door. $33 a case, not too shabby.
Richard Pike
MKIII N420P (420ldPoops)
ray anderson wrote:
Help, help,
Ray
UltraStar
TN Do no archive
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
