bakerocb
Posted: Thu May 18, 2006 3:23 am Post subject: ELT Antenna Placement |
Responding to an AeroElectric-List message previously posted by: "Dan
Beadle" <Dan.Beadle(at)hq.InclineSoftworks.com>
I am building RV8. I am trying to figure out all the antenna placements
before closing up the wings.
.....skip.......* ELT - should be on top - maybe just ahead of Vert
Stab.....skip
5/18/2006
Hello Dan, One of my friends commented that I had my ELT antenna installed
with
improper orientation. I said "Fine, tell me just exactly what attitude my
fuselage will be in when I am finished crashing and I will reinstall my
antenna accordingly." He smiled and got the point.
What attitude will your fuselage be in when you finish crashing?
OC
PS: The garden variety 121.5 Mhz ELT is just congressionally mandated dead
weight. Put the ELT in because you have to. Carry a personal locator beacon
because you want to. http://www.sarsat.noaa.gov/emerbcns.html. A cell phone
and a hand held VHF comm radio are also beneficial.
nuckollsr(at)cox.net Guest
Posted: Thu May 25, 2006 4:46 am Post subject: ELT Antenna Placement |
......skip.......* ELT - should be on top - maybe just ahead of Vert
Stab.....skip
5/18/2006
with
OC
The reasoning behind placement of ELT antennas just forward of
the vertical fin has nothing to do with final orientation of
wreckage . . . and lots to do with using the vertical fin
structure to protect the antenna as much as possible.
The 121.5/406 MHz antennas on a Beechjet are mounted under
a fiberglas toe-cap at the base of the vertical fin. See:
http://www.aeroelectric.com/temp/400A_ELT.jpg
This is about as protected a location as one can devise . . .
< with experiment. >
< --Lawrence M. Krauss >
gmcjetpilot(at)yahoo.com Guest
Posted: Fri May 26, 2006 9:22 am Post subject: ELT Antenna Placement |
Reading TSO'ed instructions for different brands of ELT's
they all tell you basically the same thing, to mount antenna:
-Vertical
-Top of fuselage
-Externally mounted
-Near ELT transmitter
-ELT is far aft as possible w/ access
(if you read between the lines there are good reasons
for every point in the installation instructions. The ELT
manufacture, not the aircraft manufactures, researched
tons of data from accidents. For best survivability of
antenna and ELT follow the instructions.)
Here is a typical oh-oops:
http://img344.imageshack.us/img344/7985/eltant7cc.jpg
I marked possible locations for ELT antenna. Of course who
know what position or condition the plane will be after a crash,
but the ELT makers know after much study the most likely.
I never read an ELT installation instruction where it stated the
reason for the ELT antenna top location is protection by the
Vert stab as Bob suggest, but from the picture it makes sense.
I also read accident reports where the ELT's are ripped off mounts
in a crash. Some crashes are just not survivable for the ELT or
the people, however talking to ELT mafct they might know better
than anyone.
FACTORY installations of ELT antennas and ELT's are not a
model of best practice. Don't know about Beech Jets but
in at least two ELT instructions there are warnings not to
necessarily follow previous factory installations when replacing
an ELT. Some factory installations are terrible.
Of course the old debate is do experimental aircraft need to
follow the TSO'ed equipments TSO'ed installation instructions?
Leave the answer to you.
As was stated there is no TSO'ed approved CRASH, so who
knows. However it's fair to say if you do want to be found the
installation instruction that came with your ELT should be
followed
If you really want to be found, the new 406 Mhz will do that better
than the old 243. The search area ratio is:
450 sq miles (old 121.5/243 Mhz)
12.5 sq miles (new 121.5/406 Mhz)
1.5 mile radius (new w/gps 121.5/406 Mhz)
How long do you think 450 sq nm can be searched with a
121.5 direction finder when your antenna is smashed down
into the ground or hidden UNDER your vertical & horz stab?
Cheers George
Quote: | >posted by: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
>Responding to post by
>>"Dan Beadle" <Dan.Beadle(at)hq.InclineSoftworks.com>
>placements before closing up the wings.
>>of Vert Stab.....skip
>ELT antenna installed with improper orientation. I said "Fine,
>tell me just exactly what attitude my fuselage will be in
>when I am finished crashing and I will reinstall my antenna
>>crashing?
Quote: | >
>OC
>of the vertical fin has nothing to do with final orientation of
>under a Fiberglas toe-cap at the base of the vertical fin. See:
>Bob . . .
Posted: Fri May 26, 2006 10:02 am Post subject: ELT Antenna Placement |
The instructions for my new Artex ME406 406 MHz ELT have additional
requirements:
"Locate the antenna at least 30 inches away from other antennas, wires,
vertical stabilizer, etc. to minimize distortion of the radiated field and
interference with other equipment. The antenna must be installed VERTICALLY
(within 15 of the vertical plane is acceptable). Artex has no performance
data for installations that deviate from the stated requirements."
(http://www.artex.net/documents/570-1600Rev-1.pdf)
This is almost impossible on my Zenith 601XL so I am doing the best I can.
-- Craig
rvbuilder(at)sausen.net Guest
Posted: Sat May 27, 2006 5:17 am Post subject: ELT Antenna Placement |
At 12:00 PM 5/26/2006 -0600, you wrote:
Quote: |
<craig(at)craigandjean.com>
requirements:
. . , which is all anyone can. Virtually every manufacturer cites
their fondest wishes in the installation manual that virtually
never work out in real life.
Generally, effects of 'deviations' require laboratory grade
instruments to detect and quantify . . . and most have no
major contribution to the outcome of any given crash/recovery
scenario.
Don't loose any sleep over it.
Posted: Sun May 28, 2006 10:52 am Post subject: ELT Antenna Placement |
Dear Bob:
To imply or suggest that an ELT is not important or complying
with installation instructions is of little consequence is not the
precise scientific well thought out response I've come to expect
out of you. The manufactures of ELT's provide instructions based
on facts and service (crash) history.
I partially agree with you, not to lose sleep and often the ELT
installation instructions can't be fully met on some small planes.
However to say:
*deviations..MOST have no major contribution to the outcome
of ANY crash/recovery scenario* is shooting from the hip.
MOST? ANY? Have proof? Data? Define, what is a deviation?
No offense, flying over Kansas or what ever flat state you're in,
is not like flying over wilderness in the Western half of the US,
Canada and Alaska, I am glad to have an ELT installed per
manufactures recommendations.
ELT manufactures might know something, you think Bob?
My suggestion is try to comply as much as possible. I know if
you call the manufacture they can provide guidance solution
(compromise). It will be more than it does not matter.
Please don't make this about you being right and me wrong.
This is about learning. A cavalier attitude is not appropriate to
the topic. Bob, you pride yourself in your facts and repeatable
experiments. I say the 1000's of crashes that the manufacture
and FAA have studied in developing the guidelines have merit,
period. If you have specifics than please say, but the general
dismissal of ELT manufactures recommendation as found
wishes is condescending.
Bob you often have FONDEST WISHES for your ideas and
concepts, you claim are based on irrefutable logic and
experiments. I think you should give other professionals in
the aerospace industry the same professional courtesy and
respect for their expertise.
Cheers George ATP/CFII-MEI, B73/75/767
Quote: | . . , which is all anyone can. Virtually every manufacturer cites
scenario.
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sun May 28, 2006 12:36 pm Post subject: ELT Antenna Placement |
On May 28, 2006, at 11:43 AM, <gmcjetpilot(at)yahoo.com>
<gmcjetpilot(at)yahoo.com> wrote:
Quote: |
Dear Bob:
However to say:
George,
The ELT is a waste of time and money. They have 97% false positives
and who knows how many false negatives. Precious few have been saved
by an ELT but a lot of people have gone on wild goose chases because
of 'em.
So, based on those facts, the placement and installation of your ELT
is going to have very little effect on its actual usefulness since it
is basically useless from the get-go. Since we are bound by law to
install these useless things in our airplanes at least we have the
option of putting them where they will be the least intrusive.
As others have stated, telling someone where you are going, what
route you are taking, and when you are going to get there is much
more effective in case of an accident than is an ELT.
And last but not least, dumping on Bob for stating the obvious is
pretty useless too.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
Antoine de Saint-Exupry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
Posted: Sun May 28, 2006 1:01 pm Post subject: ELT Antenna Placement |
Quote: | The ELT is a waste of time and money. They have 97% false positives
of 'em.
I have personnaly witnessed more than a dozen such wild goose chases for
ELT gone wild while sitting on the ramp.
About a decade ago, two friends took a plane in our flying club, for a
40 minute flight to Annecy in the French Alps. They never returned.
We spent more than a week searching the whole area, by air and on the
ground.
Finally a rambler found the wreck just two miles South of the airfield,
6000 ft high in the mountains. When the rescue helicopter landed near
what remained of the airplane, they heard the ELT transmitting : the
battery was still in good shape after 8 days, but the certified factory
installed antenna radiated only only a few yards away.
At least one of them had survived the crash, and died of exposure...
Had the antenna worked as expected, they would have been found within
hours after being overdue.
As homebuilts are not subject to ELT obligations in may area, I have the
impression that a cellphone provides much more accurate positioning
information, and for free.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
Posted: Sun May 28, 2006 1:12 pm Post subject: ELT Antenna Placement |
May be next to useless but only an idiot would take dead over 3% chance.
My short $0.02 on this mostly useless thread tangant.
Michael Sausen
And do not archive this whole thread. (wish that worked)
Posted: Mon May 29, 2006 6:24 am Post subject: ELT Antenna Placement |
At 11:43 AM 5/28/2006 -0700, you wrote:
Quote: |
Dear Bob:
And when did I say any such thing? What I said was that
every manufacturer of a product has his/her wish list
of things you should do to optimize the performance of his/her
product. Your ABILITY to comply with all those wishes is limited
by the particulars of your installation and one seldom
finds it possible to comply with ALL the manufacturer's
wishes.
The notion that the ELT manufacturer did anything based on
service history (other than fixing failures) is wishful thinking.
ELTs, like all other black boxes on TC aircraft are built to
specifications written by folks who almost never have any
experience in the manufacturing venue. The specs are then blessed
by a cadre of bureaucrats who have some knowledge of crash
history but only a few understand what they know. The golden
idea is that if Tonka Toys decides to get into the ELT business
and they've been ISO 9000 qualified, then all the have to do
is jump the intermediate hoops and meet the spec and all will
be right with the world. The idea that most manufacturers
have a nervous system that extends to the far reaches of
their customer's experience base is wishful thinking.
However to say:
A deviation is anything which does not fully comply with
the manufacturer's recommendations . . . which are often
sufficiently vague as to defy any quantification as to
cause/effect or cost/benefits.
Knowing what I've learned and come to understand about
over the years about transmitters, receivers, antennas,
patterns and propagation efficiencies, I was NOT shooting from the
hip. Each communications link is first designed with
head-room for uncontrollable losses due to atmospheric and
physical conditions. We know that NO ELT antenna installation
on an aircraft can be ideal, especially small aircraft.
Therefore, worries as to exact placement are pointless.
As I mentioned, it's more important that the antenna SURVIVE
than for the antenna to be 100% effective with respect to
ideal conditions.
Yup, they USUALLY know everything there is to know about
their product (until the guy who designed it retires or
gets a better job, then big chunks of tribal-knowledge
goes out the door with him).
But they have limited understanding of the situations in which
their product will be used . . . there are simply too many
variations on a theme. Hence, the broad brush, sweeping,
generally non-quantified recommendations.
Never recommended anything different . . . do the BEST
you can knowing that even the manufacturer cannot tell
you what effect "deviations" might have. They can only
say that deviations generate risks to performance. Will
your particular "deviation" reduce probability of being
found by 50%, 1%, 0.1%? Nobody knows, ESPECIALLY the
folks who make the ELT.
I work with those folks George. I install and trouble
shoot installations of their equipment. For the most part,
when things are not going well their fall-back position
is the same as for any other farmed-out black-box installed
on a certified aircraft: "We meet the specs, we passed our
acceptance test procedure, and our QA manual has been
blessed by your QA police. Therefor, our product is golden."
Translation: "Yes, we know how our box works but haven't
the foggiest notion of how YOU might have screwed up
in YOUR installation." In the recent case cited for
ELT self-test trips, we DID screw it up.
Respect is not a right George, it must be earned. Many
folks I've worked with over the years have my highest
respect and confidence. Others in spite of their QA manuals,
holy-watered PMAs and TSOed products would not be allowed
to wash my dog. It's not that they're evil, have unsavory
personalities, etc. They just don't understand and do
not have a charter from their management to achieve
necessary levels of understanding.
It's the very rare manufacturer who understands both
his product and its utilization well enough to be an
effective assistant in solving problems. I've been doing
this for 25 years George and I can remember only a hand-full
of cases where the manufacturer of a mis-behaving product
has been helpful in deducing and fixing root cause. The
sum total of these situations have cost my employers
tens of $millions$ . . . I can name you a half dozen
situations right now that piddle away $millions$ a year
on truly dumb wrestling matches between suppliers (them)
and customers (us).
But I never said that it wasn't a good thing to attempt
compliance with the ELT manufacturer's instructions
to the letter. What I did say was that your ability to
fully comply was not only difficult but that the effects
of your non-compliance are impossible to deduce. I'll
suggest further that no fielded installation fully complies
with the manufacturer's fondest wishes.
bruceflys(at)comcast.net Guest
Posted: Mon May 29, 2006 10:51 am Post subject: ELT Antenna Placement |
The April 2006 issue of Sport Aviation, the EAA's primary magazine, had a
lengthy article on ELTs. Here are some quotes:
[....with studies showing the false alarm rate is 99 percent.
[....with the older units failing to activate when intended two-thirds of
the time.
[Evidence also suggests the units broadcast a satellite-useable post-crash
signal only a tenth of the time.
[The new ELTs...digital transmitter broadcasts in bursts at 5 watts, a huge
improvement over the 0.1 watt analog signal of the 121.5 frequency ELTs.]
So Bob has it right. The ELT manufacturers and the FAA came up with a
flawed system using 30 year old technology, which never worked as intended.
Unlike some participants on this forum, they have learned from experience,
and designed the new 406 MHz ELT system as a replacement.
Regards, Bruce McGregor
