ron.mcgann(at)baesystems. Guest
Posted: Sun May 28, 2006 9:01 pm Post subject: Hole sizes conduits and static lines |
G'day all,
About to start wiring and static plumbing. Does anyone know of limitations on the size of holes that can be drilled into the fuse bulkheads/ribs to accommodate conduit and/or bushings? I am particularly interested in any constraints on the F-1006C bulkhead (at the tailcone join), for the static pressure lines and potential GRT AHRS/magnetometer wire runs. I already have a conduit installed under the baggage and rear set floor pans via 7/8" holes in the F-1005 and F-1034A bulkheads.
TIA
Ron
187 Fuse/Finishing
