Re : lower cowl opening for 914 only?
johnwigney(at)windstream.
PostPosted: Mon Jan 16, 2012 7:49 am    Post subject: Re : lower cowl opening for 914 only? Reply with quote
Hi Graeme,
When I built my plane, I also cut out that inlet. It is still open after 10 years and 800 hours and I am not aware of any ill effects. I have never had any cooling problems and in the winter, I have to partially mask my oil and water coolers to maintain temperatures. I would suggest leaving it alone.
Cheers, John
N262WF, mono XS, 912S
Mooresville, North Carolina
ORIGINAL MESSAGE
[quote]Subject: lower cowl opening for 914 only?
From: "graeme bird" <graeme(at)gdbmk.co.uk> (graeme(at)gdbmk.co.uk)
Had a sudden panic that I had unnecessarily opened up the lower cowl starboard
NACA duct and that it was only required for 914 inlet and not my 912. I cant see
what its for for the 912ULS as it would only cool the oil tank (which is already
too cool in flight) and possibly one end of the exhaust.
Is it necessary, has anyone filled it in?
Graeme Bird
G-UMPY
Mono Classic/XS FWFD 912ULS/Warp drive FP
Just Test Flying to obtain permit
raimo.toivio(at)rwm.fi
PostPosted: Mon Jan 16, 2012 8:57 am    Post subject: Re : lower cowl opening for 914 only? Reply with quote
Hi Graeme,
I opened it also and installed there a taxi light (HID Xenon – check an attachment).
Now if you some day decide to go for 914 you have much less to do!
No reason for panic!
Cheers, Raimo Toivio
[img]cid:04859F088860451ABA8E4E5E431E287C(at)Asus[/img]
Europa XS Mono OH-XRT #417
Updated flight hours /landings: 258,15 /466
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
toivio(at)fly.to (toivio(at)fly.to)
www.rwm.fi
Sent: Monday, January 16, 2012 5:44 PM
To: graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk) ; Europa-List (europa-list(at)matronics.com)
Subject: Re : lower cowl opening for 914 only?
Hi Graeme,
Cheers, John
ORIGINAL MESSAGE
From: "graeme bird" mailto:graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)
Graeme Bird
G-UMPY
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
 Filesize:  58.84 KB
 Viewed:  1952 Time(s)
 Filesize:  229.27 KB
 Filesize:  21.91 KB
frans(at)privatepilots.nl
PostPosted: Mon Jan 16, 2012 9:21 am    Post subject: Re : lower cowl opening for 914 only? Reply with quote
Well, in that case to make you aware of it:
Diverting air, rushing by with a speed of 100+ knots, from a smooth path
alongside the airplane, instead into a hole with lots of obstacles,
sharp turns, etc and letting it out again as a turbulent mass in the
wrong direction and with the wrong speed, is certainly costly in terms
of performance and efficiency. And in this case for no usefull purpose.
Maybe you have invested a lot of effort to make the airplane as smooth
as possible, in that case such a needless source of drag is an even
larger waste.
As a general rule you should close off all unnessecary holes in an
airplane. This is the reason why you have made the covers for the torque
tube access holes. You can leave them off without any ill effects,
except of course a reduction in speed and fuel efficiency.
Frans
