max8992
				 Posted: Mon Jan 16, 2012 9:48 am    Post subject: lower cowl opening for 914 only? Maintain temp on  cold weat |
				Hi there All,
 Some collateral question about maintaining oil and cylinders temperatures
 during cold weather (I have ~70°C when external temp is 0°C): has anyone
 installed some mechanism to deviate fresh air from the radiators, as I have
 seen on other home built planes? Any REX?
 Max  Cointe
 F-PMLH TriGear Kit #560
 912ULS Airmaster 400 hours
 -----Message d'origine-----
 De : owner-europa-list-server(at)matronics.com
 [mailto:owner-europa-list-server(at)matronics.com] De la part de Frans Veldman
 Envoyé : lundi 16 janvier 2012 18:15
 À : europa-list(at)matronics.com
 Objet : Re: Re : lower cowl opening for 914 only?
 On 01/16/2012 04:44 PM, John Wigney wrote:
  	  | Quote: | 	 		   It is still open after
  10 years and 800 hours and I am not aware of any ill effects.
 Well, in that case to make you aware of it:
 Diverting air, rushing by with a speed of 100+ knots, from a smooth path
 alongside the airplane, instead into a hole with lots of obstacles,
 sharp turns, etc and letting it out again as a turbulent mass in the
 wrong direction and with the wrong speed, is certainly costly in terms
 of performance and efficiency. And in this case for no usefull purpose.
 Maybe you have invested a lot of effort to make the airplane as smooth
 as possible, in that case such a needless source of drag is an even
 larger waste.
 As a general rule you should close off all unnessecary holes in an
 airplane. This is the reason why you have made the covers for the torque
 tube access holes. You can leave them off without any ill effects,
 except of course a reduction in speed and fuel efficiency.
 Frans
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Max8992
Europa XS #560 F-PMLH |
