		sidsel.svein(at)oslo.onli Guest
				 Posted: Tue Jan 17, 2012 2:34 am    Post subject: SV: Exhaust joints |
				Jon,
 The Rotax installation manual for 912ULS states on p.42:  "All ball joints
 have to be greased regularly with heat resistant lubricant (e.g. LOCTITE
 ANTISEIZE) to avoid gripping and seizing the joints."
 I think you can use any recognized copper based exhaust system grease
 available at auto supply stores.
 Whether such lubricant also has a sealing effect over time is doubtful.  If
 you have any seizure marks due to stuck joints, some exhaust gas may escape
 along these marks.
 On the cylinder joints, have you checked that the nuts are torque correctly?
 I had a problem with nuts coming loose, but have now safety wired the nuts.
 Svein
 LN-SKJ
		JonSmith
				 Posted: Tue Jan 17, 2012 10:52 am    Post subject: Re: SV: Exhaust joints |
				Hi Svein,
 Very many thanks for your reply and for directing me to the section in the Rotax installation manual - I had missed that and it indeed tells the story!
 Cheers, Jon
  _________________ G-TERN
Classic Mono |
