chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Fri Jan 20, 2012 9:46 pm Post subject: Grand rapids cs02 / cs01 amp sensor |
Hi all
> I am installing a Grand Rapids J6000 EIS in my aircraft.
> > Where have people wired the amp current sensor? and through whit size
> > wire was it?
> > There are 2 different current sensors and they are for different size
> > wires?
> > you can use the CS-01 or CS-02 or amps. the most important difference
> > is the size wire that is allowed for each.
> > the CS-01 100amp can fit up to a #4 wire and the CS-02 50amp can only
> > fit up to #6 wire. so if you're using a big battery cable most
> > people require the #4 wire and the CS-01.
> > So which one to use and where did you fit it in the elec circuit on a
> > Jab3300?
> > Chris
> > Zodiac XL
> > Jab 3300
