Two Speed Controller and Relay Deck for Ray-Allen actuators
PostPosted: Mon Jan 23, 2012 4:01 pm    Post subject: Two Speed Controller and Relay Deck for Ray-Allen actuators Reply with quote
At 01:08 PM 1/22/2012, you wrote:
The same ebay company had this:
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=250975404341#ht_4310wt_1398
Looks like it would be an economical alternative to the high dollar relay decks used with stick grip switches, etc. The relay coils are 5V, but a handful of dropping resistors or a 5V supply feeding the control switches would solve that.
If your talking about Ray-Allen actuators, this would be
horrible overkill. These actuators need about 100 mA for
operation. The relays needed are simple one-pole, double-
throw devices available in 12 or 24 volts for under $4.
The bill of materials to build an adjustable, two-speed
controller is under $10. See:
http://www.aeroelectric.com/PPS/Flight/Trim/Two_Speed_Trim_2.pdf
Except for the selection of relay (12/24) the bill of
materials is the same for installing a 2-speed Ray-Allen
trim actuator in either a 14 or 28v airplane.
With a tad more head scratching, the relays can be replaced
with transistors and a circuit could be evolved that would
work in either 14/28 volt airplanes.
One COULD use a big honk'n down converter and use it to
run all trim systems and power cockpit accessories.
Bob . . . [quote][b]
