woxofswa
Posted: Fri Jan 27, 2012 7:11 am Post subject: Kitlog help |
I hope the brain trust can help me with a problem. I did a pretty extensive update to my construction log last night, but when I went to print the new pages to add to my hardcopy, I discovered that my pagination was off. Trying to sort out the problem, I discovered that the pictures from the bottom row of each page are rolling over to the next page thereby increasing my total number of pages and throwing off the pagination. On several previous updates, this never happened before, but I can't seem to find a way to get it back to the way it was.
Thanks in advance.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
rleffler
Posted: Fri Jan 27, 2012 8:28 am Post subject: Kitlog help |
The conversion routines for print output just plain suck it Kitlog. I've attempted to work on this issue with Matt on multiple occasions over the years. I'm not optimistic that there will ever be a new release that fixes all the issues.
In that regards, I've come up with many workarounds. In this case, I have acrobat installed which includes a PDF print driver. I just use the native print command going to a PDF file, which solves the issue you describe.
Spending time on getting his embedded crystal report module to work right won't be time well spent. There are several other errors like this that pop up when your db reaches a certain size. Print to a PDF and not using the report module converts has solved them all for me.
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse in mostly done, finishing kit in progress.
http://forums.matronics.com/viewtopic.php?p=364939#364939
_________________ Bob Leffler
N410BL - Phase I
woxofswa
Posted: Fri Jan 27, 2012 11:44 am Post subject: Re: Kitlog help |
Thanks Bob,
I'll give that a try. At the same time as dealing with this fiasco, I'm dealing with the Mediasearch virus and am about to let my computer say hello to my "little friend" H&K .40 and a full clip or two of his little friends.
Mesa, AZ
Flew May 10 2014 |
woxofswa
Posted: Fri Jan 27, 2012 3:25 pm Post subject: Re: Kitlog help |
I tried the PDF option, but just keep getting an "unhandled exception" message and then it either quits or locks up.
Mesa, AZ
Flew May 10 2014 |
