Dorne & Margolin DM C63-1 antenna
jerrytex
PostPosted: Tue Jan 31, 2012 12:37 pm    Post subject: Dorne & Margolin DM C63-1 antenna Reply with quote
I have a DM C63-1 antenna that I need to relocate on my kitfox. It is inside the fuselage (done by another builder) and it will not transmit since it is basically in a cage of tubing. My fuselage has been modified with the factory mounting plates removed. I have an idea about making a clamping type plate that I can slip under the fabric and mount to the tubes but the top of the fuselage has a "Spline" and is not flat so the antenna would be off to one side. I am thinking about a belly mount and was curious to know if anyone has ever bent the DM antennas? I know they make a bent one (DM C63-2) but I am wondering if I could just bend the one I have I have to meet the clearance needed for a belly mount.
