David d.
Joined: 04 Jul 2011 Posts: 60 Location: Fitzgerald Ga.
Posted: Fri Jan 27, 2012 5:35 pm Post subject: Nose Skid Strip |
A while back there was a post about a home made nose skid.
My search skills are about like my airline pilot skills.
It had pictures and etc.
Can any one direct me to the link
Thanks David d.
_________________ Kolb Mark IIIX 582 Blue head |
russkinne(at)mac.com Guest
Posted: Fri Jan 27, 2012 5:54 pm Post subject: Nose Skid Strip |
David
Can't help with the nose-skid, but why did I get four identical messages from you? Plugs things up.
Thanks David d.
http://forums.matronics.com/viewtopic.php?p=365003#365003
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Fri Jan 27, 2012 6:43 pm Post subject: Re: Nose Skid Strip |
Do a search for "nose skid". I posted some pictures of my design some time ago. Some people liked it; others raised a fuss.
I got an email from TNK at the time & they were complimentary and had no problems with it.
I use it as a front pull handle, tie down point if required, and I also attached my pitot and static tubes to it.
Rex Rodebush
David d.
Posted: Sat Jan 28, 2012 9:43 am Post subject: Re: Nose Skid Strip |
Well Rus, It seems that ya cant help me but I can help ya with the 4 sided presentation. Give ya computer a a fleet inema. That should unplug it for a while.
David d.
Posted: Sat Jan 28, 2012 9:49 am Post subject: Re: Nose Skid Strip |
Rex,
I did do multiple searchs for nose skids, loops, plates, etc. As stated it did not return any such plans or picutures.
Could some one kindly just send a link. TIA
David d.
Rex Rodebush
Rex Rodebush
Posted: Sat Jan 28, 2012 11:16 am Post subject: Re: Nose Skid Strip |
David,
Do a search for "rodebush". All my posts should come up. Click on "nose bracket" and the pictures should come up.
If that doesn't work let me know & I'll send you the pictures direct via email.
Rex
Ozarkflyer
Joined: 19 Jun 2009 Posts: 68 Location: Mtn. View, AR
Posted: Sat Jan 28, 2012 2:38 pm Post subject: Re: Nose Skid Strip |
I found it by searching for just "skid". Otherwise, every post with "nose" in it will come up.
_________________ DO NOT ARCHIVE |
David d.
Posted: Sun Jan 29, 2012 4:48 am Post subject: Re: Nose Skid Strip |
Okay, after much searching, I found the link to the hoop thingy.
http://wingsforum.com/viewtopic.php?t=174
I dont know where the wings forum is, but all info is there except, what is the metal used? From the pictures it could be Al. Steel or Stainless?
I have PM ed to Planecrazzzy, but so far no reply.
Has any one else built and use one of these?
David d.
Rex Rodebush
Posted: Sun Jan 29, 2012 12:16 pm Post subject: Re: Nose Skid Strip |
David,
That's a nice skid but not mine. If you are on the BBS Matronics forum just hit the search at the top. I have about 4 or 5 pictures.
I made mine from standard aircraft 4130 steel tubing.
Rex
David d.
Posted: Sun Jan 29, 2012 5:09 pm Post subject: Re: Nose Skid Strip |
Thanks Rex, but yours was installed as your plane was built. I have a Mk III that I recently purchased and want the add on type. And it can be removed easily later. With out knowing I will build it with steel or stainless.
David d.
pj.ladd(at)btinternet.com Guest
Posted: Mon Jan 30, 2012 2:15 am Post subject: Nose Skid Strip |
Hi David,
Dont know how you are going to fix your nose bow. To be of real use there
has to be some lateral bracing which will make it heavy.
I had a pitot in that position and wiped it off twice in early taxying
sessions going for a burst of power to make a 180 turn before I had learned
to hold the stick back.
After that holding the stick back becomes second nature .
Pat
Rex Rodebush
Posted: Mon Jan 30, 2012 9:21 am Post subject: Re: Nose Skid Strip |
David,
Yes, you're in for a little more work. You will have to pull the nose cone at minimum. I welded some support tubes for the skid from the horizontal section in front of the cage. I think TNK eliminated that section on later models for weight reduction as it really doesn't do much from a stress/load point of view.
The benefit may not be worth the amount of work. It's up to you.
But you never know. Last month I tied the tail down and was running up the engine again for some instrument checks (elevators not installed yet). I left the tie down too slack and dumped the cage on the nose at full power. I was glad for the skid as it probably saved me a dinged nose cone.
Rex
