markn(at)fuse.net Guest
Posted: Tue May 30, 2006 1:51 pm Post subject: L-40 Alternator Output |
I am using B&C's L-40 alternator and have just completed the 40 hour Phase 1
flight testing. Now that I am considering night flight, I have begun testing
my lighting system.
I noticed that turning all electrical equipment (Nav, landing, panel lights,
pitot heat and radios) puts a draw of about -15 amps on the ammeter at 1500
RPM. I did a load analysis earlier and I calculated full system load is 34
amps.
Is this just a simple case of alternator overload or could there be
something else? I put in the alt field test point as The Aeroelectric
Connection suggests. At full load, the field voltage is changing between 11
and 12 volts. I would conclude from this that the alternator is putting out
everything it has but I'm still at a deficit.
Is this alternator really able to put out the full 40 amps as advertised, or
am I just drawing more power than calculated?
Any suggestions on a 60-80 amp automotive alternator with external
regulation?
Mark Neubauer
(513) 583-1222
mstewart(at)iss.net Guest
Posted: Tue May 30, 2006 2:31 pm Post subject: L-40 Alternator Output |
Mark hows your system voltage while at a cruise rpm?
Mike
markacarey(at)msn.com Guest
Posted: Tue May 30, 2006 6:49 pm Post subject: L-40 Alternator Output |
| Quote: | From what I understand there is a considerable variation with RPM. For
instance the 20 AMP B&C only puts out 12 amps at 2000 but it generates 18 at
2500. My approach is to install the 40 as a primary and use the 20 in place
of the vacuum pump for night approaches if needed (or rely on the battery
for a short time). The pitot is a big draw that is likely a rare need at
night.
[quote]From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
Reply-To: aeroelectric-list(at)matronics.com
To: <aeroelectric-list(at)matronics.com>
Subject: RE: L-40 Alternator Output
Date: Tue, 30 May 2006 18:05:40 -0400
Mike
nuckollsr(at)cox.net Guest
Posted: Wed May 31, 2006 5:19 am Post subject: L-40 Alternator Output |
At 07:44 PM 5/30/2006 -0700, you wrote:
night.
The stated RPM vs. OUTPUT values are for alternator RPM, not
engine RPM. If you're mounted on a Lycoming with about 4:1
pulley ratio, you should be able to get full output from
any alternator at anything higher than taxi RPM on engine.
You need to conduct some data measurements per Note 8 of:
http://aeroelectric.com/articles/Rev11/AppZ_R11G.pdf
And get back to us. In particular, we need to know the field
voltage and bus voltage when you're experiencing the "insufficient
output" condition noted in your first posting. The need for
knowing field voltage as a diagnostic tool was the reason
for crafting Z-23 in the Z-figures.
