rdmac(at)swbell.net Guest
Posted: Mon May 29, 2006 8:16 am Post subject: Nose Wheel Shimmy |
I got a question for you guy or gals that fly unconventional gear Kitfoxs.
Every sense installing the faring on the nose wheel, I have had a
reoccurring shimmy.
I have tightened the pivot nut on the strut and have also added some
pressure to the tire. I thought I had it fixed but after going out and
flying this morning, before the wind got up, it did it again when I landed.
Is there something I haven't tried or I'm doing wrong.
Roger Mac
S7/912s
roncarolnikko(at)hotmail. Guest
Posted: Mon May 29, 2006 2:59 pm Post subject: Nose Wheel Shimmy |
Hi Roger I have to keep the air pressure down in the 152 nosewheel. The tire
carries on all of the tread not just the middle. Might help the Fox. Ron
NB Or
| Quote: | From: "Roger McConnell" <rdmac(at)swbell.net>
Subject: Nose Wheel Shimmy
Date: Mon, 29 May 2006 11:13:29 -0500
reoccurring shimmy.
Roger Mac
S7/912s
Is your PC infected? Get a FREE online computer virus scan from McAfee
Security. http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
smokey_bear_40220(at)yaho Guest
Posted: Tue May 30, 2006 10:32 am Post subject: Nose Wheel Shimmy |
Hi Roger,
High speed shopping cart? Can you balance the
wheel/tire?
Kurt S.
--- Roger McConnell <rdmac(at)swbell.net> wrote:
I have had a reoccurring shimmy......
jdmcbean(at)cableone.net Guest
Posted: Tue May 30, 2006 8:23 pm Post subject: Nose Wheel Shimmy |
Roger,
The most common issue with the nose wheel shimmy is the strut axle nut.. it
needs to be tight enough that it requires about 12-14 lbs of break away
pressure if one was to grab the rear of the tire... You can adjust it by
using a fish scale and hook it to the aft of the tire. It does not need to
maintain that pressure but it should be close to that to get the tire to
start turning...
Hope that helps...
Fly Safe !!
John & Debra McBean
www.sportplanellc.com
"The Sky is not the Limit... It's a Playground"
Posted: Wed May 31, 2006 2:57 pm Post subject: Nose Wheel Shimmy |
John and others
Thanks for the advice; I do recall something in the build manual
about using a fish scale. I'm not a fisherman so guess I'll borrow or go buy
one. Now let's see if its 12-14 lbs at the rear of the tire what do you
figure it to be at the rear of the faring? Think I'll try 6-8 lbs.
Roger Mac
DO NOT ARCHIVE
wingsdown(at)comcast.net Guest
Posted: Wed May 31, 2006 8:31 pm Post subject: Nose Wheel Shimmy |
I would not pull on the fairing that far aft....
Fly Safe !!
John & Debra McBean
bnn(at)nethere.com Guest
Posted: Fri Jun 02, 2006 7:23 pm Post subject: Nose Wheel Shimmy |
At 09:13 AM 5/29/2006, you wrote:
| Quote: | Every sense installing the faring on the nose wheel, I have had a
reoccurring shimmy.
Wall occors its shimmyin'. Yur tryin' t fly the plane bakwards, dummy! The
wheals sposed to be in da back!
(Sorry, couldn't resist.)
Guy Buchanan
K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar.
dan(at)azshowersolutions. Guest
Posted: Sat Jun 03, 2006 4:35 am Post subject: Nose Wheel Shimmy |
Guy,
Ifin da wheel is sposed ta be in da back...why da heck duz it keep wantin ta moove roun to da frunt?
Dan Billingsley
Mesa
Kitfox IV , 912s, TriGear
reoccurring shimmy.
Guy Buchanan
dosmythe(at)cox.net Guest
Posted: Sat Jun 03, 2006 4:44 am Post subject: Nose Wheel Shimmy |
Good come back. Couldn't help but laugh so early in the morning.
Don Smythe
Posted: Sat Jun 03, 2006 11:18 am Post subject: Nose Wheel Shimmy |
At 05:31 AM 6/3/2006, you wrote:
| Quote: | Guy,
Dan Billingsley
Mesa
HAHAHAHAHA! Thanks.
(Tee hee.)
Guy Buchanan
