sandbag23(at)msn.com Guest
Posted: Sat Feb 18, 2012 6:09 pm Post subject: Oil consumption has increased...maybe |
I've been losing more oil than usual�so am now both tracking consumption more closely and looking for ways to decrease it.
Research had dissuaded me from considering air-oil separators.� I'm going to do the trick of rerouting the breather hose in a higher arc under Gary's cowl.� I'm wondering if there's a venturi effect going on too.��The 'whistle' slot is way up inside.� My question is how far should the tube extend from the Jaguar cowl?� Same 1inch +/- 1/2inch?� Gary is probably the only one who knows the pressures and flows enough to say.�
So what happened?� Maybe just normal engine wear on a mid-time engine, or maybe I'm running it harder because I can with the new cowl.� By the way, I'm consistently seeing roughly 5-10 KTAS better than book with about .5 gph less than book for the given�rpm (tach is accurate) leaned aggressively by ear (from just rough back to smooth) and backed up by a JPI EDM-700.� So that's a reliable 135KTAS at around 9.0gph in the mid altitudes (2500rpm).� Besides the steps off, K&N air filter, and powerflow (as required by the STC) my airplane is mostly stock and a bit bent.
-Brian
119ST (at) 2W6
| - The Matronics TeamGrumman-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?TeamGrumman-List |
teamgrumman(at)yahoo.com Guest
Posted: Sat Feb 18, 2012 7:04 pm Post subject: Oil consumption has increased...maybe |
Brian,
When I fly at high rpm (>2700), I always burn more oil. I don't think I've ever flown at 2500 rpm (smile).
Where do you keep the oil level?
On my plane, I have the breather out about 1 to 1 1/2 inches.
Check compressions for blow-by. An air-oil separator will only cost you money. I have 3 of the M-20 air-oil separators. I'd sell you one. (smile)
To: Team Grumman <teamgrumman-list(at)matronics.com>
Sent: Saturday, February 18, 2012 6:09 PM
Subject: Oil consumption has increased...maybe
I've been losing more oil than usual so am now both tracking consumption more closely and looking for ways to decrease it.
Research had dissuaded me from considering air-oil separators. I'm going to do the trick of rerouting the breather hose in a higher arc under Gary's cowl. I'm wondering if there's a venturi effect going on too. The 'whistle' slot is way up inside. My question is how far should the tube extend from the Jaguar cowl? Same 1inch +/- 1/2inch? Gary is probably the only one who knows the pressures and flows enough to say.
So what happened? Maybe just normal engine wear on a mid-time engine, or maybe I'm running it harder because I can with the new cowl. By the way, I'm consistently seeing roughly 5-10 KTAS better than book with about .5 gph less than book for the given rpm (tach is accurate) leaned aggressively by ear (from just rough back to smooth) and backed up by a JPI EDM-700. So that's a reliable 135KTAS at around 9.0gph in the mid altitudes (2500rpm). Besides the steps off, K&N air filter, and powerflow (as required by the STC) my airplane is mostly stock and a bit bent.
-Brian
119ST (at) 2W6
flyv35b(at)minetfiber.com Guest
Posted: Sun Feb 19, 2012 2:42 pm Post subject: Oil consumption has increased...maybe |
On 2/18/2012 7:02 PM, Gary Vogt wrote:
Quote: | Check compressions for blow-by. An air-oil separator will only cost you
The M-20 is almost worthless!
Cliff
BARRY CHECK 6
Posted: Sun Feb 19, 2012 5:07 pm Post subject: Oil consumption has increased...maybe |
No it's not Cliff...
It made a lot of money for the guy that holds the STC.
Barry
On Sun, Feb 19, 2012 at 5:42 PM, flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)> wrote:
[quote]--> TeamGrumman-List message posted by: flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
Cliff
List" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
http://forums.matronics.com
le, List Admin.
Posted: Mon Feb 20, 2012 6:04 am Post subject: Oil consumption has increased...maybe |
On 2/19/2012 5:06 PM, FLYaDIVE wrote:
Barry
Duh! But still worthless (almost) at taking oil vapor out of the
crankcase breather and returning the oil back to the engine.
If you saw the oil (and water) that is being returned to the engine I
don't think you would want the air-oil separator. Heck, run it in to a
container and at least that way you can empty it once in awhile.
Cliff
slacktide
Posted: Mon Feb 20, 2012 5:49 pm Post subject: Oil consumption has increased...maybe |
It can also be an effective tool to remove crank nose seals.� Take an M20 out of service, put it in the freezer overnight, then cut it in half with a bandsaw.� Tell me how it is supposed to function as a breather then...
DWB
On Mon, Feb 20, 2012 at 6:04 AM, flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)> wrote:
[quote] --> TeamGrumman-List message posted by: flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
Barry
Duh! �But still worthless (almost) at taking oil vapor out of the crankcase breather and returning the oil back to the engine.
If you saw the oil �(and water) that is being returned to the engine I don't think you would want the air-oil separator. �Heck, run it in to a container and at least that way you can empty it once in awhile.
Cliff
le, List Admin.
Posted: Mon Feb 20, 2012 6:58 pm Post subject: Oil consumption has increased...maybe |
you give it too much credit
Sent: Sunday, February 19, 2012 2:42 PM
Subject: Re: Oil consumption has increased...maybe
The M-20 is a= - The TeamGrumman-List Email Forum -http://www.matronics.com/Navigator?TeamGrumman-List<========================
