johnwigney(at)windstream. Guest
Posted: Tue Feb 21, 2012 8:56 am Post subject: Re : Smooth Prime |
Hi Fred,
I did my whole plane with Smooth Prime. I found it very easy to apply with a small diameter foam roller and small plastic paint tray. Instructions are at http://www.polyfiber.com/uvsmooth/
I did the 3 coats and sanded down with 320 grit. Sanded down again with 320 after another 3 coats. Sanding of Smooth Prime to get a good finish is very easy. As I remember the dilution, if any, was as specified on the can. I sprayed Aerothane topcoat after this with good results. I understand that some have had problems with the topcoat possibly due to inadequate drying of the water based Smooth Prime. Instructions are very clear that it should be left for 3 weeks to dry. Poly Fiber now recommend sealing the Smooth Prime with epoxy primer. I did not do this as it was not specified when I did the job.
Re quantity, I do not remember. Suggest you start with 1 gallon and see how you get on.
Cheers, John
[quote]ORIGINAL MESSAGE
From: Fred Klein <fklein(at)orcasonline.com> (fklein(at)orcasonline.com)
Subject: Smooth Prime
To those of you who have used Smooth Prime on their Europa XS...Have you used it JUST on the filled/foam control surfaces?...or on the ENTIRE airframe?
In either case, how much material is necessary for the required THREE (undiluted) COATS before sanding?
Thanks in advance,
Fred[b]
steven.pitt2(at)ntlworld. Guest
Posted: Tue Feb 21, 2012 9:50 am Post subject: Re : Smooth Prime |
John et al,
I did my trigear in Smooth Prime for all the positives that have already been stated. I then had the aircraft professionally painted (rather than by me) and after 5 years I am still very happy with the results. However one other UK builder has not had such a good result with the same Smooth Prime and same painter although it is being rectified in good order.
I was always told that damp was the main problem with the Poly Fiber system ie it has to be absolutely dry before top coating and I know that mine went into a newly built oven on a low heat after having 'cured' in my garage for a couple of years after I painted the primer on.
I was interested to hear that the recommendation is now to seal with an epoxy primer and I can see the logic but who does it - the builder or the painter and does the primer also need sanding down.
At the end of the day you pays your money and .......
As I said I was delighted with my aircraft finish and would recommend Smooth Prime again with the caveat.
Steve Pitt
G-SMDH
Trigear XS 912S
Posted: Wed Feb 22, 2012 3:27 am Post subject: Re : Smooth Prime |
Guys, If you haven't already bought the Smooth Prime, I
strongly suggest giving some thought to gel coat. As far
as I know every competitive fibreglass glider uses this
system because it gives the ultimate finish, is very
durable, andgives ultimate aerodynamic performance. After
10 years my plane still has a surface which outshines
virtually all Europas. The process is also simple: it
needs a single sprayed layer (no primer, undercoat or UV
protection - the gel is itself UV opaque) and then is
rubbed down with wet & dry sandpaper 600, 1200 & 2000
grit. The finish is like the bit of anatomy that Cuban
virgins are alleged to use for rolling the best sort of
cigars!, and is absolutely what laminar flow surfaces
need. Unlike dry sanding, wet & dry finishing is a
pleasure. It is sometimes said to be heavy but my plane is
one of the lightest 914/wobbly prop planes on the
register. The only thing I would advise is that you get
the actual spraying done by an expert, someone who is used
to gel coating gliders.
regards, David Joyce, G-XSDJ
On Tue, 21 Feb 2012 11:55:38 -0500
John Wigney <johnwigney(at)windstream.net> wrote:
| Quote: | Hi Fred,
job.
Cheers, John
ORIGINAL MESSAGE
Thanks in advance,
Fred
