riddon(at)sent.com Guest
Posted: Thu Mar 08, 2012 7:31 am Post subject: Rough running 912S NO MORE!! |
Thanks for all your input guys. I am embarrassed to say that I have found the problem. Same as Pete below, I had left the vent pipes disconnected after removing the plenum chamber to check some coolant pipes for leakage a while ago. I guess this also explains the strong fuel smell when the engine was running.
I will save all your answers for next time!!
Now smooth as the proverbial baby's bottom.
Richard Iddon
G-RIXS
On 7 Mar 2012, at 16:50, Pete Lawless wrote:
Richard
Have you got the little plastic pipes from the carbs connected into the air
box?
I have had exactly the same symptoms on my 912 when I left the pipes
unconnected after working on the aeroplane. Good in the climb and missing
and rough when I pulled the power back.
Pete
