icubob(at)newnorth.net Guest
Posted: Sun May 28, 2006 5:27 am Post subject: elt antenna |
hi all, this topic was recently discussed on another list. timely as i =
was installing my elt. a few facts came out of the discussion
1] elts fail to function in over 90% of accidents
2] no matter where you mount an elt you have no control how the =
airplane will come to rest in a crash...upside down, right side up, on =
its nose.
3] the best insurance for a quick recovery is filing a vfr flight plan =
if you can.
after the discussion i quit losing sleep about where to put my elt =
antenna.
bob noffs
nuckollsr(at)cox.net Guest
Posted: Sun May 28, 2006 7:01 am Post subject: elt antenna |
I read a piece some time ago . . . I think in AOPA Pilot.
The stats on ELT effectiveness were discussed. I'm think I'm
recalling that the data being studied was for all ELTs which
included a large population of the earliest 121.5, carrier
plus modulation suitable only for aural i.d. of a beacon.
The numbers were NOT encouraging.
It's true that the earliest systems were hampered by the
inability of a satellite system's rudimentary position
calculation system to get a location on the beacon.
It took multiple passes of satellites and some calculation
to get a rough idea of where to look for you. Read HOURS
ELT's are now available that report your GPS position
so that your location is known upon first detection of
the signal. The advantages of this feature are obvious.
If ANY ELT is installed, I'd use one with the GPS reporting
feature.
Even without the reporting feature, ELT locating hardware
and software is much more sophisticated. Your location
is likely to be deduced in minutes and with much greater
accuracy.
Quote: | 2] no matter where you mount an elt you have no control how the =
its nose.
True . . . but being upside down is not an automatic
turn-off of the ELT's ability to transmit. Remember,
we're talking line of sight transmission where very
small transmitters and relatively inefficient antennas
are able to cross the gap. It's more important that the
antenna and transmitter remain INTACT than to worry
about perfect positioning. This is why a location in
front of the vertical fin was chosen . . . for the
any benefits that the fin structure might offer in
keeping the antenna from being broken off.
Quote: | 3] the best insurance for a quick recovery is filing a vfr flight plan =
if you can.
Every little bit helps. Having someone watch
to see if you arrive at the expected time and location
is yet another layer of risk mitigation . . . but simply
knowing that you're not at the appointed place at the
appointed time is a small piece of a huge puzzle.
Having a beacon broadcasting your location to the world
with a accuracy of a few meters is about the best risk
mitigator we have in the current tool box.
I would also carry a hand held and plenty of spare
batteries. In the US at least, there are dozens of
aircraft within your line of sight location at any
given time. If I ran the FAA, I'd allocate a second
emergency frequency, SEPARATE from 121.5 as a CRASHCOM
service. Alerts for missing aircraft could be put out
not unlike the Amber Alerts for missing children. If
any en route air transport category airplane within
150 miles of your location is listening, you'll be
able to talk to them from your hand-held. Having a hand
held GPS to back up your ELT's ability to report position
is a good thing to have too.
Posted: Sun May 28, 2006 11:32 am Post subject: elt antenna |
As best I can tell feeding GPS coordinates into the new generation of ELTs
is a *very* expensive proposition - at least when sticking to Artex's
products. First you have to switch from their "cheap" model ME406 to the
G406 to get a unit which accepts GPS coordinates ($1456 vs. $839). Then you
have to buy their Nav/ELT interface box (455-6500), about $1358). And (from
what I can make out from the specs) the interface box only accepts serial
data in the form sent by expensive in-panel GPS receivers, not the NMEA 0183
format from cheap portable units.
The alternative is to buy a Personal Locator Beacon like the McMurdo
Fastfind. The model with a GPS built-in costs $573. But a PLB is manually
triggered, not by a G sensor. So it doesn't do any good if you are
unconscious. I live in the mountainous west where there are lots of out of
the way places to crash. I guess I can rationalize buying a PLB by saying
that if I remain unconscious too long to activate the PLB then I'll probably
be dead by the time I am rescued. The PLB would just get me found faster
after a crash where I am in relatively good shape.
-- Craig
rv8ch
Posted: Sun May 28, 2006 12:39 pm Post subject: elt antenna |
unconscious. ...
Couldn't you activate the PLB before you hit the ground, and hope it
survives the impact?
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
gmcjetpilot(at)yahoo.com Guest
Posted: Mon May 29, 2006 1:11 am Post subject: elt antenna |
Here is why ELT's exist (first par):
http://www.wsdot.wa.gov/aviation/SAR/ELT_History.htm
The rest is extremely interesting and highlights the state of
confusion with the new 406 ELT's. You may be able to use
your old 121.5/243 ELT after Feb 2009 but it may be even
less effective than it's today. Clearly the 406 ELT can get
your position within a mile or two to 100 yards with GPS.
Faults alarms where addressed with TSO-C91a (verse the old C91)
http://www.avionicswest.com/myviewpoint/boringarticle.htm
The newer TSO ELTs require small annunciator/control
panel to be installed somewhere in the cabin and provide a
visual indication via a blinking light when the ELT is
activated and of course, turn off the ELT if need be.
However the wsdot article says many ELT faults alerts
are not even from ELT's!
The avionicswest article mentions the new PLB's as
others have mentioned. I agree there awesome devices
many should consider as a backup, especially if you are
into outdoor sports of any kind. I remember stories of
people going off the side of the road and not being
found for many days just feet from a major freeway, hurt
but alive. Many PLB's have built in GPS position!
What I hear and read the 2009 deadline may be extended.
That's not a good thing since the satellites WILL? still stop
monitoring 121.5/243 regardless! AOPA is asking for a
voluntary replacement program. Reading the advantage
of 406 ELT's it seems like a no brainier?
Before the satellites monitored for ELT's in the 70's ELT
location method was with local DF only. Lets say 406 ELTs
are not made mandatory. With out the satellites your
chance of being found with old fashion DF is slim to none.
George
rv8ch
Posted: Mon May 29, 2006 2:44 am Post subject: elt antenna |
I can argue both sides of the mandatory ELT issue. With
my Libertarian hat on, I think it should be up to the builder
to decide if they want a PLB/ELT in their aircraft, and
they have to live (or die) with the consequences. The
problem comes in when there are unwary passengers on the
aircraft, and/or public resources are used to try to find
the downed aircraft.
Of course, we could simply say that if you don't have a
PLB/ELT, then you need to placard this for passengers,
and if there is a search and rescue launched to recover
your body, then your spouse/estate will get billed for the costs.
Putting on the Statist hat (I don't have one - I'd have to
borrow it), if PLB/ELT devices are required, then they
will end up costing less, and search and rescue missions
will probably also cost less and be more effective. We
may even find a survivor or two.
I fly with an ELT simply because I am required to do so,
and I plan to upgrade to a PLB "soon", but I wouldn't
want to impose my choices on anyone else.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
BobsV35B(at)aol.com Guest
Posted: Mon May 29, 2006 4:46 am Post subject: elt antenna |
In a message dated 5/29/2006 5:46:30 A.M. Central Standard Time,
mick-matronics(at)rv8.ch writes:
Me Too
(Sorry Matt, I just couldn't resist!)
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
Posted: Mon May 29, 2006 6:26 am Post subject: elt antenna |
At 01:26 PM 5/28/2006 -0600, you wrote:
Quote: |
<craig(at)craigandjean.com>
Here's an opportunity for some of you byte thrashers out there.
A $1 PIC microcontroller and a handful of jellybean parts could
probably be crafted to convert NMEA 0183 into the golden format.
GPS engines are about $50 each. You could craft a stand-alone
GPS enhancement adapter for the bare-bones GPS capable ELT.
w_sweet(at)comcast.net Guest
Posted: Mon May 29, 2006 10:30 am Post subject: elt antenna |
I feel much the same as Bob Nuffs. However I NEVER file an VFR flight =
plan. UHHHH...... OOOOHHHH
I ALWAYS use flight following and have been refused service rarely and =
only in high density areas around Class B airspace. If one has a problem =
while under radar contact, you get immediate assistance in the form of =
radar vectors if needed. AND more importantly, they know precisely =
where you are. Only in very mountainous situations is radar contact =
lost, but at least the area of crash landing is known. Too many =
searches, when there is one, begin searching nearly a whole state. More =
important than that is the search will be put in motion right then at =
the time of radar contact lost. ATC can even be an aid in vectoring =
search aircraft to the general area.=20
ELT's need a quantum jump is technology to provide the needed =
information and reliability to be truly useful.
Wayne
Bill Schlatterer
Posted: Mon May 29, 2006 11:19 am Post subject: elt antenna |
Mickey, I think the PLBs are a better option as well but have not seen any
data on them in actual use. Do you have any info that would suggest that a
PLB signal is more likely to be received than a ELT if the PLB is inside an
upside down metal aircraft ?? (typical Vans) Would the burst signal that a
PLB generates, be more likely to radiate out or be contained by the
structure? I assume the PLB to be a line of sight signal.
Thanks Bill S
7a wiring
Posted: Mon May 29, 2006 12:19 pm Post subject: elt antenna |
Since ELTs are required (and not a bad investment either) I see PLBs as an
addition, not an alternative. And my expected mode of use would be after
extracting myself (if possible) from the plane. Certainly as a general plan
those of us flying planes with bubble canopies should plan ahead for ways to
get ourselves out of an inverted plane on the ground. Or have a tool at hand
that can at least cut or break a hand-sized (and PLB-sized?) opening in the
canopy.
www.ch601.org/stories.htm
-- Craig
rv8ch
Posted: Mon May 29, 2006 1:57 pm Post subject: elt antenna |
Quote: | Mickey, I think the PLBs are a better option as well but have not seen any
Hi Bill,
No, I don't have any data on how effective the PLB will
be in the real world. Hopefully some of the gurus can
chime in and give us an idea if they think it will be
better.
As I understand the PLB, they talk to one or more
satellites, so that would need to be line of sight.
Their frequency is higher, which should allow a
shorter antenna. Hopefully they will get small
and cheap enough that we could afford to put in a
few of them in the aircraft, so no matter what part
survives, there is an PLB/ELT in there.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
