frans(at)privatepilots.nl Guest
Posted: Tue Mar 13, 2012 12:07 pm Post subject: Rotax 914 starting problems when hot |
Hi everyone,
I guess I'm not the only one having this problem. The main problem here
is that I don't understand why it is happening.
If I arrive at an airfield in hot weather, I can restart either right
away, or after a considerable time. If I just refuel without having a
meal, I get into a time window where the engine has difficulties starting.
It is a vapour lock problem of some sort, but I don't know how this can
happen. Sure, the inside of the cowling is hot and residual heat from
the turbo is, without the large fan upfront turning, cooking the fuel.
But I thought that the 914 is supposed to be immune from the problem.
Up to the pressure regulator the fuel is recycling when I switch on the
electric fuel pump. Any vapour up to the pressure regulator is directed
back into the tank and being replaced by fresh and cold fuel.
The carb bowls might have been cooked empty, but then the floats will
have dropped and fresh fuel will pour in as soon as I switch on the
pumps. The fuel line between the pressur regulator is not recycled but
if it contains vapour then it will escape via the opened carb needle and
not raise the floats, so it will gently escape until being replaced by
liquid fuel, being driven there by the electric pumps.
So... why won't then darn thing just start?
Yesterday I was exactly experiencing this problem. After arriving at an
airport to go to the service center for the bi-annual pitot and static
systems test, and with the engine switched off for about ten minutes I
couldn't restart it. No matter how long I kept the fuel pumps running,
applied choke, (just in case the mixture was too lean) or was just
cranking with the throtthle wide open to vent the cylinders (in case it
was too rich), the engine would just crank without even a faint single hit.
So I abandoned the plan to taxi to the refueling station, and had a
lunch instead. Of course after that the engine started up right after
just a half turn of the prop...
So... why is this happening? I'm interested in solving this problem, but
primarily I want to know why this is happening because according to my
reasoning it shouldn't be happening in the first place. What am I
missing here?
Oh BTW, on the return home I got caught by non predicted early set in of
night fog, with a very rapidly dropping cloud base (never seen it
falling that fast). With my home base being the closest and most
promising airfield once I got forced down to 500 feet I advanced the
throttle to 100% (not 115%) and got over 155 knots IAS worth out of it
on my freshly calibrated ASI, which was quite an experience so low over
the ground. At my homefield I arrived less than 15 minutes later with
the local cloud base still at 1000 feet (as announced/predicted by ATC
half an hour earlier), but I was thankful nevertheless to have been able
to speed out of that threathening situation that fast. If it weren't for
the obligatory static/pitot test to renew my airworthiness review
certificate I wouldn't have been flying at all that day, so much for the
bureaucrats that want to enforce my safety this way. Anyway, the
pitot/static systems worked flawless (I would have had noticed it myself
it if they weren't) and I'm good to apply for renewal of the desired
certificate.
All this while I had unwittingly broke my smallest toe by bumping into
my wife unintentionally (honestly!) and was undergoing this flying
experience with some discomfort to enhance the flying experience even
further. At least the latter problem has been diagnosed correctly today,
so now I just want to get diagnosed the vapour lock problem as well. Who
can shine some light on this mystery?
Frans
ward.t(at)xtra.co.nz Guest
Posted: Tue Mar 13, 2012 1:23 pm Post subject: Rotax 914 starting problems when hot |
Frans,
Don't have a 914 but I know others who have suffered the same problem with
the 912S and , for what it is worth, they always
open their oil and coolant doors on top of the top cowling to allow faster
cooling of the engine compartment during stopovers.
Otherwise don't mention starting problems to me! I have now got to replace
my Sprag Clutch due to cold starting problems with my 912S
at 300 hours!! Always had it and got worse with time. So watch out when
trying to persist in trying to start the motor as it quickly destroys your
Sprag Clutch. I have also the
old mono "classic" engine frame which doesn't allow enough room for the new
Heavy Duty Starter which Rotax suddenly decided was
necessary for the 100 HP 912S. So, after replacing the Sprag Clutch, the
Rotax man is going to look at how to fix the starting problem
in cold weather. Maybe a case of redesigning the engine frame to allow for
the HD Starter?
Once it is going there is no problems with starting, so I haven't got the
vapour lock problem.
All a bit frustrating as you have found out and expensive. Might as well
throw in the 912iS, but that may unleash a different set of problems.
Anyone have some input to my problem? Tried new battery, preheating the
engine which has helped, haven't tried the soft start module,
and kicking the tyre!!
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nz
paul.the.aviator(at)gmail Guest
Posted: Tue Mar 13, 2012 4:21 pm Post subject: Rotax 914 starting problems when hot |
Hello Frans,
I have the same problem. I find if I turn the fuel pump off when I crank and the turn them on after the engine starts works well for me.
BTW, I have called a couple of times, have you been away?
Cheers, Paul
On Tuesday, March 13, 2012, Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)> wrote:
| Quote: | Hi everyone,
[quote] meal, I get into a time window where the engine has difficulties starting.
Posted: Tue Mar 13, 2012 4:26 pm Post subject: Rotax 914 starting problems when hot |
Tim,
I have found setting the plug gap to the minimum specified helps with cold starting.
Paul
| Quote: | Otherwise don't mention starting problems to me! I have now got to replace my Sprag Clutch due to cold starting problems with my 912S
> at 300 hours!! Always had it and got worse with time. So watch out when trying to persist in trying to start the motor as it quickly destroys your Sprag Clutch. I have also the
| Quote: | old mono "classic" engine frame which doesn't allow enough room for the new Heavy Duty Starter which Rotax suddenly decided was
> necessary for the 100 HP 912S. So, after replacing the Sprag Clutch, the Rotax man is going to look at how to fix the starting problem
[quote] in cold weather. Maybe a case of redesigning the engine frame to allow for the HD Starter?
daseitz(at)cfl.rr.com Guest
Posted: Tue Mar 13, 2012 6:12 pm Post subject: Rotax 914 starting problems when hot |
OK, I'll put my two cents in on this one. Ever since my 914 was new it has had this problem. Starts right away oe after half hour, but not after ten minutes. When this happens it is flooded. it will start firing with the throtle almost full open and finally start running. This is with both pumps off. After it starts turning the pump on will flood it again. I have to bump the pump on for a moment at high RPM wait till it clears and bump again until it will stay running then all is well.
I have asked when down at Lockwood and all they would say is the carbs need to be rebuilt. If this is the case it was sold to me new with bad carbs since it has done it from day one.
I have given up trying to figure it out. If anyone can let us know. In the meantime I an making my own fuel injection system for it. So far I have it running from 2000 to 4000 rpm on the ground tests. This will be able to run on the carbs or the injection. I hope to make it available when it is finished for under $4000.00 It will still be a while before all the desiging and testing will be completed though.
Be nice if someone could figure the flooding problem out in the meantime
Dean Seitz
---- Frans Veldman <frans(at)privatepilots.nl> wrote:
Hi everyone,
missing here?
certificate.
Frans
klinefelter.kevin(at)gmai Guest
Posted: Tue Mar 13, 2012 8:19 pm Post subject: Rotax 914 starting problems when hot |
Hot start on my 914 is no choke, closed throttle, start cranking and slowly advancing the throttle untill it fires up.
Kevin
914 mono 400hrs.
On Mar 13, 2012, at 1:01 PM, Frans Veldman <frans(at)privatepilots.nl> wrote:
Hi everyone,
missing here?
certificate.
Frans
g-iani(at)ntlworld.com Guest
Posted: Wed Mar 14, 2012 1:07 am Post subject: Rotax 914 starting problems when hot |
Frans
This problem drove me mad for a couple of years until I discovered the magic trick Ivor described.
Turn off both pumps and start the engine with about a 1/8in to ¼in of throttle. It will fire up and run but you must
leave the pumps off until she starts to falter (say 5 to 10 seconds). Then turn on the main fuel pump and she continues to run.
This has worked well on both G-IANI and G-IRON (both 914) for the last six years.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
watervet(at)mweb.co.za Guest
Posted: Wed Mar 14, 2012 1:45 am Post subject: Rotax 914 starting problems when hot |
Hi Frans
Have exactly the same problem with my 914 - ok straight away but short break very difficult to start - but have found if I do 2 things
I can get it to start agin with little extra effort.
1. Open both inspection hatches once you have landed - allows some of the under cowl heat to escape.
2. To start - switch on a fuel pump till you have good fuel pressure ( i have a fuel pressure warning light - wait till it goes out) then switch OFF the fuel pumps - open throttle to about a 1/4 +/- and crank till it fires - once engine is running - switch on fuel pump but be prepared to switch off again if engine starts to die - soon running smooth and fuel pump can be left on as normal
Dr Mike Toft BVSc
083 654 6655
P O Box 602
Linkhills 3652
watervet(at)mweb.co.za (watervet(at)mweb.co.za)
On 13 Mar 2012, at 11:22 PM, Tim Ward wrote:
[quote]--> Europa-List message posted by: "Tim Ward" <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)>
Frans,
Don't have a 914 but I know others who have suffered the same problem with the 912S and , for what it is worth, they always
open their oil and coolant doors on top of the top cowling to allow faster cooling of the engine compartment during stopovers.
Once it is going there is no problems with starting, so I haven't got the vapour lock problem.
All a bit frustrating as you have found out and expensive. Might as well throw in the 912iS, but that may unleash a different set of problems.
Anyone have some input to my problem? Tried new battery, preheating the engine which has helped, haven't tried the soft start module,
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
bill.sue(at)orcon.net.nz Guest
Posted: Wed Mar 14, 2012 1:57 am Post subject: Rotax 914 starting problems when hot |
Franz,
I sometimes have this problem during hot weather. My solution is to turn
OFF both fuel pumps and then it starts easily. As soon as it starts turn
the pump back on and all is OK.
Sue& Bill
On 14/03/2012 9:01 a.m., Frans Veldman wrote:
Hi everyone,
missing here?
certificate.
Frans
raimo.toivio(at)rwm.fi Guest
Posted: Wed Mar 14, 2012 3:44 am Post subject: Rotax 914 starting problems when hot |
Great Frans
"I advanced the
IAS worth out of it
on my freshly calibrated ASI,"
Congratulations for that; next upgrade your very
speedy cannon to Mono and meet even VNE (165
knots) during the low level flight.
"broke my smallest toe by bumping into
my wife unintentionally (honestly!)"
I recommend you to try next time your biggest tool
intentionally instead of a smallest toe
unintentionally.
Raimo
do archive
-----Alkuperäinen viesti-----
Sent: Tuesday, March 13, 2012 10:01 PM
Subject: Rotax 914 starting problems
when hot
Hi everyone,
residual heat from
cold fuel.
as I switch on the
is not recycled but
pumps.
about ten minutes I
fuel pumps running,
lean) or was just
station, and had a
place. What am I
missing here?
(never seen it
closest and most
feet I advanced the
IAS worth out of it
minutes later with
way. Anyway, the
certificate.
toe by bumping into
Frans
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
Posted: Wed Mar 14, 2012 3:54 am Post subject: Rotax 914 starting problems when hot |
On 03/13/2012 10:00 PM, PHILLIPS I wrote:
| Quote: | I turn off both pumps with about a 1/4 throttle it will fire up and run
but you must
leave the pumps off until she starts to falter,
Thanks a lot! You, and of course everyone else who answered. Good to
hear I'm not the only one having this problem and good to hear there is
consencus about the work around to get the thing started.
Nobody came up with a suggestion why we are having this problem. Let's
see, now it is clear that the engine will start with the fuel pumps off,
we can draw some conclusions from it: It is not a fuel starvation
problem, so it is not vapour lock.
I think the best (if not only) explanation is:
After 10 minutes in a hot engine bay the fuel in the carb bowls has
vaporized completely and is then lingering in the airbox and manifold
with no easy way out, so it is still there when we try to start the
engine after these 10 minutes. The mixture is overly rich due to the
excessive fuel vapor and allowing the carbs to add the normal amount of
fuel will make the mixture so rich that the engine won't start. If we
start right after shut down the fuel in the carbs has not yet vaporized,
if we start much later the vapor has leaked away so it is not causing a
problem anymore.
Anyone else with a better explanation?
I thought of fixing this problem but now the work around is so easy I
think I will leave it at that.
Thanks everyone!
Frans
Posted: Wed Mar 14, 2012 3:58 am Post subject: Rotax 914 starting problems when hot |
On 03/13/2012 10:22 PM, Tim Ward wrote:
| Quote: | So watch out when
your Sprag Clutch.
The 912S has a much higher compression than the 914 (and 912). Although
never owned a 912S it was my understanding that the starting issues have
to do with this higher compression, which makes cranking the engine much
harder with much more jolts and kicks.
I guess a larger battery and retarding the ignition during starting
might help a bit.
Frans
Posted: Wed Mar 14, 2012 4:01 am Post subject: Rotax 914 starting problems when hot |
On 03/14/2012 01:20 AM, Paul McAllister wrote:
| Quote: | BTW, I have called a couple of times, have you been away?
Yes, I have been away yesterday and the day before. Now I first have to
get a pile of work done, I guess we can call later (when it is evening
here).
Frans
Posted: Wed Mar 14, 2012 4:17 am Post subject: Rotax 914 starting problems when hot |
On 03/14/2012 03:11 AM, Dean Seitz wrote:
| Quote: | I have asked when down at Lockwood and all they would
Same here. It has always done that. And with only 150 hours on the clock
I think the carbs are still pretty new.
| Quote: | In the
Great, I'm working on plans to do the same. You are also using the carbs
as throttle body (and for redundancy in case the injection fails?)
| Quote: | I hope to make it
Are you working on it as a commercial project or is this a fun project
we can openly discuss? If it is the latter I would love to know where
and how you obtained adapted manifolds with injector bosses.
| Quote: | It will still be a
I bet! But it is worth the effort, I estimate a fuel reduction of 10%
and a slight increase of power. With the current fuel prices the system
will earn itself back.
| Quote: | Be nice if someone could figure the flooding problem out in the
meantime
What do you think about my theory?
Frans
djaflyact(at)gmail.com Guest
Posted: Wed Mar 14, 2012 8:11 am Post subject: Rotax 914 starting problems when hot |
I have found, over the years, that if I run the engine taxiing in with the fuel pumps off and then shut it down as the engine starts to falter, that leaves the carb bowls empty. Then on start-up, the carbs are filled with fresh, cool fuel and with the techniques described, it starts right up. I do leave the pumps off during the start and then start them when the engine starts to falter.
Not sure why this has to be done, but it is necessary. I also leave the inspection doors open to help remove the hot air from the top of the cowl while it is parked.
Dave Anderson
480 hours
914 long wing.
Posted: Wed Mar 14, 2012 8:39 am Post subject: Rotax 914 starting problems when hot |
On 03/14/2012 05:08 PM, DAVID ANDERSON wrote:
| Quote: | I have found, over the years, that if I run the engine taxiing in
That is a smart idea! I like this one. It should solve the problem, and
it also causes less residu to be built up in the carbs. (If fuel
vaporizes some residues from the various additions remain, if the carb
is drawn empty these residues can not built up in the first place).
| Quote: | Then on start-up, the carbs
I'm not sure if I understand this right. You switch the fuel pumps off
on arrival and let the engine sputter to a halt due to fuel starvation,
and then you leave the fuel pumps still off at the subsequent start??? I
assume that you use either one of these options but not both at the same
time because otherwise there wouldn't be any fuel available for
starting? Please clarify?
Frans
neveyre(at)aol.co.uk Guest
Posted: Wed Mar 14, 2012 11:31 am Post subject: Rotax 914 starting problems when hot |
Hi Frans,
I believe heat is the trigger to your [ and other 914 drivers] initial problem.
Can you provide us with the under cowl temps you saw during your Flight Test Program ?
The numbers you witnessed in cruise, climb out and after shut down / resting ? I was monitoring these temps in several places inside the cowl during development of the original 912 and 914 Installation, would be interesting to see how the removal of all through air flow has effected under cowl temps. Heat from the exhaust / Turbo has to go somewhere ?
Nev.
Posted: Wed Mar 14, 2012 11:55 am Post subject: Rotax 914 starting problems when hot |
Hi Neville,
| Quote: | Can you provide us with the under cowl temps you saw during your Flight
Test Program ?
Nope, don't have that data. But I plan to do some measurements this summer.
| Quote: | would be
I bet it is much lower than it was before. The air leaving the radiator
blows right between the exhaust tubes and turbo. Air box temp (I have a
sensor there) is also lower than it used to be. And I have no signs of
elevated temps in the cowling (no discolourisation, no melted tie wraps,
etc).
Of course, once the engine is switched off the radiant heat will still
heat up everything and boil away the fuel.
Frans
