Tim Olson
Posted: Wed Mar 21, 2012 6:29 am Post subject: Brake Pads? |
Desser Tire http://vansaircrafttires.com/
Skygeek.com
Aircraft Spruce
Van's
I've bought from them all. Desser has the Rapco pads.
For the Cleveland's you'd go to the other places.
Tim
On 3/21/2012 9:08 AM, Jim Combs wrote:
| Quote: | I am looking for a supplier of brake pads for the -10. I have rivets
and the rivet tool to set them.
Anyone got a good supplier they could recommend or not?
Jim Combs (N312F - 350 hours)
Rv10flyer(at)verizon.net Guest
Posted: Wed Mar 21, 2012 6:38 am Post subject: Brake Pads? |
Desser has a RV-10 specific page.
They sell pads, rapco I believe.
On Mar 21, 2012, at 7:08 AM, Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
[quote]I am looking for a supplier of brake pads for the -10. I have rivets
Ron B.
Posted: Mon Sep 03, 2012 2:55 pm Post subject: Re: Brake Pads? |
I don't see the RV-10 pads listed on Desser's site. Am I missing them or are they no longer available.
Thanks Ron
Bob Turner
Posted: Mon Sep 03, 2012 3:55 pm Post subject: Re: Brake Pads? |
Ron, as posted also on VAF, Rapco is apparently no longer making them. I emailed Desser a few months ago and they did not have any, and did not know if or when they ever would.
But, the Rapco pads for the 10 were still twice as expensive as the pads for any other RV, just a few dollars less than the Clevelands ($19 per pad from Chief, with no rivets included).
_________________ Bob Turner
RV-10 QB |
rnewman(at)tcwtech.com Guest
Posted: Mon Sep 03, 2012 4:09 pm Post subject: Brake Pads? |
You are not missing anything. I called them to order the Rapco pads and
got the following story when I then called Rapco. They are going to have
the brake pads, hopefully in the next few weeks. They made an initial set
for PMA qualification testing, but haven't made any since as they await the
FAA approval. The initial build were the ones that some folks were able
to buy, but now are out of stock. They told me the testing was complete
and they were awaiting the paperwork, so perhaps they will actually be
available soon. Also, they led me to believe the price would be coming
down to about $12 per lining.
Bob Newman
N541RV
rv10flyer
Posted: Mon Sep 03, 2012 5:16 pm Post subject: Re: Brake Pads? |
When someone hears they are available again, please post.
I am only at 76.9 hrs, but I like keeping spares on hand of oil filter/oil/tires/tubes/pads/start & master contactors/fuel selector valve/prop oring/caliper oring. I have all but pads and caliper oring in case someone gets in a bind and is near S. Ohio.
_________________ Wayne G. |
Kellym
Posted: Mon Sep 03, 2012 6:07 pm Post subject: Brake Pads? |
What kind of life are folks experiencing with their brake pads? I would
hope at least 300 hours, perhaps more.
On 9/3/2012 6:16 PM, rv10flyer wrote:
Wayne Gillispie
http://forums.matronics.com/viewtopic.php?p=382350#382350
Checked by AVG - www.avg.com
KCHD |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Mon Sep 03, 2012 6:31 pm Post subject: Brake Pads? |
Of course we all think we are good on our brakes but I "believe" I have been
pretty easy on mine. I have been mostly landing on long runways and not
needing to get on them. When I finally replaced mine they were literally
1/128 from the rivets. I looked at them around 190 flight hours and thought
I had some room for more flights when I probably should have replaced them.
Mine started to grab so I cleaned them up replaced the O-ring and liners at
247 hours. As you recall Kelly, you replied to my question about replacing
the parts but all I needed to do was replace the liners, O-rings and bleed
them. I used that lube you recommended and so far they have worked great.
I think when the puck was close to the end of its travel it was causing the
assembly to wedge against the rotor causing it to rub and stick. So I would
say around 200 flight hours the liners should be replaced. I guess it would
be more accurate to look at cycles but I haven't calculated that yet.
On another note we all have heard from Vans that lower pressure was better
for vibration. I filled my tires up to 50psi and they work really good this
way. I built the gear leg stiffeners out of wood and glassed them in. It
really resolved the vibration except for days I was extremely light. When I
was really light I still felt a little vibration on my right gear leg. Now
I have 50 PSI in the tires and absolutely no vibration.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
robin(at)PaintTheWeb.com Guest
Posted: Mon Sep 03, 2012 9:22 pm Post subject: Brake Pads? |
I run a little higher psi too and have no shimmy with no stiffeners. I usually fly solo but rarely land with less than half tanks.
I have a feeling that most -10 pilots will go through their first set of pads a lot faster than subsequent sets due to knowing your craft better. Drive that plane with your heels on the floor as much as you can.
Robin
rv10flyer(at)verizon.net Guest
Posted: Tue Sep 04, 2012 7:59 am Post subject: Brake Pads? |
My contact is out this week but I'll follow-up next week and see if I can
get a status on the pads. I thought he told me he was getting a new supply
after OSH, maybe he sold off that stock already, which is surprising
considering how many he was getting. Supposedly the "old" stock was far more
durable than the new ones Rapco is working on getting certified or
something. A few months back Rapco mentioned that the new ones would be out
by SnF, than it was OSH.
Hopefully I'll be able to get a more official response on options by next
week.
scottmschmidt(at)yahoo.co Guest
Posted: Fri Sep 07, 2012 12:37 pm Post subject: Brake Pads? |
I typically fly between 100 - 200 hours per year and put new pads on every annual. My first two years I flew 250 hours and I replaced them at 230 hours.
http://www.vansairforce.com/community/showthread.php?p=149271#post149271
It is a pretty cheap item compared to the problems it may cause when your on a trip away from your tools. If you replaced them at 200 hours you would probably be safe and could start to extend the time depending on your flying and braking.
Scott Schmidtscottmschmidt(at)yahoo.com
[quote] From: Pascal <rv10flyer(at)verizon.net>
Sent: Tuesday, September 4, 2012 9:58 AM
Subject: Re: Re: Brake Pads?
--> RV10-List message posted by: "Pascal" <rv10flyer(at)verizon.net (rv10flyer(at)verizon.net)>
My contact is out this week but I'll follow-up next week and see if I can get a status on the pads. I thought he told me he was getting a new supply after OSH, maybe he sold off that stock already, which is surprising considering how many he was getting. Supposedly the "old" stock was far more durable than the new ones Rapco is working on getting certified or something. A few months back Rapco mentioned that the new ones would be out by SnF, than it was OSH.
Hopefully I'll be able to get a more official response on options by next week.
Tim Olson
Posted: Fri Sep 07, 2012 2:08 pm Post subject: Brake Pads? |
Yeah, I agree with Scott, I don't do them exactly at annual, but more
based on hours in service. But, while I don't remember the time I
put on for the first set, something tells me it was about 170 hours
and that was just enough for me to hit the rivets on one side and
grind a groove in my disk. I got less hard on brakes after that
first year, so Scott's 200 or so is probably a real good number
as a maximum for your first year with an RV-10. You MAY be able
to squeak a little more life out of them, but my guess is that most
builders should probably plan to replace BY 150 on their first
year....get a good measurement, change your bad habits, and maybe
shoot for a max of 200-250 after you learn how to be conservative
on brakes. Then you should do OK.
FWIW, this is why I am not a person who puts an air-fill hole in
my wheel fairings. If you use leakguard tubes, you only need to
fill up every 9 months or so anyway, so if I pull the fairings
every spring and fall, it gives me at minimum, 2 times a year
when I can inspect the linings. If I had a fill hole, I'd be
more tempted to just "fill er up" and keep flying without inspecting
the linings. Probably cause more harm than the convenience is worth.
Tim
On 9/7/2012 3:36 PM, Scott Schmidt wrote:
[quote] I typically fly between 100 - 200 hours per year and put new pads on
at 230 hours.
Scott Schmidt
*To:* rv10-list(at)matronics.com
*Sent:* Tuesday, September 4, 2012 9:58 AM
*Subject:* Re: Re: Brake Pads?
<mailto:rv10flyer(at)verizon.net>>
next week.
Posted: Fri Sep 07, 2012 3:15 pm Post subject: Brake Pads? |
I would agree with this as well, except that you can inspect the brake linings with a mirror and flashlight. I like the fill hole.
Do not archive.
On Sep 7, 2012, at 6:07 PM, Tim Olson <Tim(at)myrv10.com> wrote:
Tim
Strasnuts
Posted: Sun Sep 16, 2012 3:41 pm Post subject: Re: Brake Pads? |
Update on brake pads.
I just ordered four more to have on hand from Aircraft Spruce. They came a week later. They are Cleveland liners and they come with rivets. The part number is 66-112. You have to actually search for this number instead of the description. Also, you have to go to the Cleveland part area and choose it from the drop down menu. Expensive though at 21.75 a pad with rivets.
Here is a link
http://www.aircraftspruce.com/catalog/lgpages/cleve_brklining.php
780 Hours
Ron B.
Posted: Wed Sep 19, 2012 2:44 pm Post subject: Re: Brake Pads? |
Just received two kits from Van's today, $88 for a set of four and rivets.
Ron
