mapratherid(at)GMAIL.COM Guest
Posted: Fri Apr 20, 2012 11:52 am Post subject: Non-Aviation Question - Electric Stove Switch |
Listers,
I acquired a fairly late model Kenmore electric range from craigslist
a few days ago. My first pass inspection verified that the oven,
clock, and all of the burners worked.. So far, so good. However, the
first time I attempted to cook on one of the large burners I learned
that it had only one setting - 100% on. Grrr.
I did a little blind checking and found that a replacement control
switch was $91 from Sears - my good deal on the range was/is in
jeopardy.. So, I started debugging - swapping the switch into the
location for the other large burner. The bad behavior tracked with
the switch - good!
Feeling nothing to lose, I disassembled the switch and found that a
set of contacts within the switch was stuck (welded?) closed - that
explained the behavior. I managed to pry the contacts open and spent
a bit of time filing on them - not sure that does any good.. I
reassembled everything and it all seems to be working properly now.
If I hold my head close to the panel, I can hear the bimetallic switch
cycling the power to the burner on and off.
Now for my questions:
- What caused the contacts to weld closed? It's a fairly new range,
so it doesn't seem like it was just a large number of cycles. I'm in
New Mexico, which has frequent lightning storms. Could the errant
charge from a lightning strike cause the contacts to get welded
closed? Maybe the previous owners of the stove used it for cooking
meth - so it has an abnormal number of cycles on it?
- Will my efforts at splitting the contacts and cleaning them up
yield a switch that's reasonably long-lived and reliable? Or should I
just order a replacement switch now.. I found an alternate source of
the switch - for $30. Is there something else I can do to the switch
contacts to help them out?
I read an article that suggests that contacts get hottest during the
arc associated with the switch opening. And that immediately
re-closing the switch offers the largest risk for welding the
contacts. I could imagine an unattended little kid playing with the
dial until it failed closed - it makes a very subtle, but kind of cool
buzz-click every time the contacts close or open...
Matt-
raymondj(at)frontiernet.n Guest
Posted: Fri Apr 20, 2012 12:45 pm Post subject: Non-Aviation Question - Electric Stove Switch |
FWIW
If the burner is thermostatically controlled, it's possible the temp
control system might have caused rapid switching leading to the welding.
Raymond Julian
Kettle River, MN
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
On 04/20/2012 02:49 PM, Matt Prather wrote:
Listers,
the switch - good!
Matt-
