ipad in the cockpit
flysrv10(at)gmail.com
PostPosted: Fri Apr 20, 2012 4:13 am    Post subject: ipad in the cockpit Reply with quote
Just thought to post my old email to the list in reference to iPad discussions.
Do nt archive.
---------- Forwarded message ----------
From: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)>
Date: Thu, Sep 23, 2010 at 7:55 PM
Subject: Fwd: iPad Mount update
I decided to relocate my iPad after my a flight test last weekend.  I found the previous location a little too distant for my taste.  I think the most ideal position is at eye level where John Miller has installed his.  Hopefully the Gizmo guys will come up with a panel mount and give those in process of planning their panel another option.
I swapped the 2" standard clamp leg with a 6" long leg from Ram Mount (they are great people to deal with) and I think that I like this arrangement much better.  The second picture shows the iPad in it's pilot-exit configuration.  Will post a flight test report this weekend.
[img]cid:B7B47C67-B360-4723-B023-71E6C38EFB62[/img]
[img]cid:C9EC74F5-9A39-4EB1-87C2-ABEA01D766A0[/img]
[img]cid:04D2ED35-275D-4726-9FBA-52B83B13F452[/img]
Begin forwarded message:
Date: September 13, 2010 6:17:08 PM EDT
Subject: iPad Mount
Reply-To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
I finally received my iPad mount from Ram Mounts.  It is a good quality and strong mount.
I used a sheet of aluminum and formed it around the tunnel to use as a temporary bracket and to mount the iPad.  Once flight testing t is complete, I will most likely remove the extra aluminum bracket and attach the mount with thru bolts to the tunnel cover.
I have pointed the iPad's charging port up under the panel; so that I can get a 12V charger and connect it behind the panel to charge continuously during flights.
Flight test, this weekend.
[img]cid:D1EFDAA2-7C60-45D8-BB73-35FD84B6F65C[/img]
[img]cid:7CEAB0A6-A98C-4B75-B4D3-A8FF2FDFA112[/img]
Rob Kermanj
 Filesize:  32.25 KB
 Viewed:  1102 Time(s)
 Filesize:  54.17 KB
 Filesize:  48.72 KB
 Filesize:  42.59 KB
 Filesize:  57.87 KB
