teamgrumman(at)yahoo.com Guest
Posted: Wed Apr 18, 2012 2:17 pm Post subject: Questions continued |
Select the items that are within the privileges and limitations of the inspection authorization.
(1) Perform a progressive inspection.
(2) Supervise a progressive inspection.
(3) Perform an annual inspection.
(4) Supervise an annual inspection.
Oddly enough, Supervising an annual is not one of them.
| | - The Matronics TeamGrumman-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?TeamGrumman-List |
Posted: Wed Apr 18, 2012 7:15 pm Post subject: Questions continued |
Records of the
1) maintenance,
2) preventive maintenance,
3) and alteration
4) and records of the 100-hour,
5) annual,
6) progressive,
7) and other required or approved inspections
as appropriate for each aircraft (including the airframe) and each engine, propeller, rotor, and appliance of an aircraft
must be retained until the work is
1) repeated or
2) superseded by other work or
3) for 1 year after the work is performed.
------- So all those old 337s can be tossed into the trash.
david(at)troup.net Guest
BARRY CHECK 6
Posted: Thu Apr 19, 2012 4:17 am Post subject: Questions continued |
When it comes to the government, the only thing that should be tossed in the trash is the government. Especially those with Dumbo Ears.
Barry
On Thu, Apr 19, 2012 at 3:52 AM, David Troup <david(at)troup.net (david(at)troup.net)> wrote:
[quote]--> TeamGrumman-List message posted by: David Troup <david(at)troup.net (david(at)troup.net)>
"So all those old 337s can be tossed into the trash."
Just wanted to point out that "can be" is not the same as "should be."
-Dave
List" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
http://forums.matronics.com
le, List Admin.
