Fuel Senders, Gauges, Accuracy
n8vim(at)arrl.net
PostPosted: Thu Jan 12, 2006 3:09 pm    Post subject: Fuel Senders, Gauges, Accuracy Reply with quote
Hi all!
Hopefully someone can give me some answers to an issue an RV-8
builder informed me of. Specifically, his tank holds 22 Gallons, he uses
15 gallons before the fuel gauge reads half. Since I don't have a gauge,
and I am about to put the rear baffle on, I'd like to get half to be as
close to half as possible!
Questions:
1. Anyone already built; With 15 Gallons in your tank:
A) What is the resistance of your sending unit?
B) What does your gauge read (half, 3/4, 1/4?)?
2. Anyone that has a gauge and the sending unit:
A) What resistance makes the gauge read:
a) 1/4
b) 1/2
c) 3/4
d) Full
Many thanks for replies!
-Jim 40384
sfdarton(at)yahoo.com
PostPosted: Thu Jan 12, 2006 3:54 pm    Post subject: Fuel Senders, Gauges, Accuracy Reply with quote
To any completed RV-10 owners
I would like to build a fuel tab Ala Cherokee. can
someone give me a dimension for 10 gallons down (20 in
the tank).
Steve 40212 Tanks
--- James Hein <n8vim(at)arrl.net> wrote:
<n8vim(at)arrl.net>
Hi all!
issue an RV-8
22 Gallons, he uses
don't have a gauge,
Questions:
tank:
unit?
1/4?)?
a) 1/4
b) 1/2
c) 3/4
d) Full
-Jim 40384
browse
Subscriptions page,
FAQ,
Admin.
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
jesse(at)itecusa.org
PostPosted: Wed Jan 18, 2006 1:46 pm    Post subject: Fuel Senders, Gauges, Accuracy Reply with quote
Jim,
We are using the floats, but are using a Dynon EMS to monitor the tanks
through the floats. When you calibrate the Dynon, they have you put in a
gallon or two at a time and it gets the new reading from the float. Having
done it this way, and having a fuel flow meter to check, and a history of
filling the tanks and using exactly what the fuel flow said we had burned,
the floats are almost always accurate within a gallon or two. Couldn't help
any on actual gauges, though. I wouldn't even consider putting a non-EMS
(read - individual gauges for monitoring engine and fuel) in a plane like
this anyway.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Fax: 815-377-3694
I am in Ecuador until May, 2006. If you have questions regarding I-TEC,
please call the office at 352-465-4545. If you would like to talk to me,
please call me at 352-505-1899. This number won't always be on, but it has
voicemail that will get to me in Ecuador.
Randy(at)abros.com
PostPosted: Wed Jan 18, 2006 4:14 pm    Post subject: Fuel Senders, Gauges, Accuracy Reply with quote
I have the same experience with the ACS2500. The fuel in the tanks is
right on compared to the gauges. Randy
