smokey_bear_40220(at)yaho Guest
				 Posted: Sat Jun 03, 2006 11:52 pm    Post subject: Performance (Was Wood Prop Advice) |
				Hi John,
 I found my best ROC speed to be very critical at 59
 knots.  My ROC dropped 9% just 2 knots faster and 22%
 just 2 knots slower.  That steep curve was the biggest
 surprise of my testing.  I thought I could get good
 enough at best ROC within +/-5 knots, but not true.
 If I really need to clear something, I have to hawk
 the speed.
 I suspect it is due to a steep drag curve that will
 improve when I add more fairings, and I wonder how
 this compares to the rest of you?  How critical is
 your climb speed?
 Another thing I need to test is flappeon angle.
 Reflexed a little might help a lot.  Those who use it
 for trim say it makes a big difference.
 Those things you could consider too.
 Combining this with your prop pitch change figures and
 what you wrote before, I'm not quite sure what limits
 you reach first.
 If you are using 5000 rpm as your upper limit, I would
 set pitch to fall just short of this RPM limit in
 level full power flight and see how it performs there
 for climb.  If you want more climb than that gives,
 you have to watch your RPM yourself.  It will not be
 self limiting with less pitch.
 If you want more cruise, you can always add more pitch
 until climb suffers too much to suit you.
 With your observed boost drop below 4300 rpm, you
 probably don't want to set pitch to give below this
 for static full power rpm.
 For me, I would set pitch to give me say 4900 at max
 speed and throttle and make sure I get more than 4400
 static.  Start from there and tweek more pitch for the
 biggest   at 4000 cruise, as long as climb is good.
 This is fun!
 Kurt S.
 --- John Anderson <janderson412(at)hotmail.com> wrote:
  	  | Quote: | 	 		   Yes Kurt, I tend to climb faster too but for the
  test result I've put it
  through the paces. 5000max, 4600 (at)55kts BRC speed
  1500'pm (just one up of
  course) and 4300 97kts level. Ive settled at 4000
  for cruise as runs
  smoothest there and 90. I notice quite a boost drop
  from 4300 down to 4000.
  I've very pleased with how well it has turned out...
 Tired of spam?  Yahoo! Mail has the best spam protection around
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
