		rdmac(at)swbell.net Guest
				 Posted: Mon May 29, 2006 8:16 am    Post subject: Nose Wheel Shimmy |
				I got a question for you guy or gals that fly unconventional gear Kitfoxs.
 Every sense installing the faring on the nose wheel, I have had a
 reoccurring shimmy.
 I have tightened the pivot nut on the strut and have also added some
 pressure to the tire. I thought I had it fixed but after going out and
 flying this morning, before the wind got up, it did it again when I landed.
 Is there something I haven't tried or I'm doing wrong.
             Roger Mac
             S7/912s
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		roncarolnikko(at)hotmail. Guest
				 Posted: Mon May 29, 2006 2:59 pm    Post subject: Nose Wheel Shimmy |
				Hi Roger I have to keep the air pressure down in the 152 nosewheel. The tire
 carries on all of the tread not just the middle.  Might help the Fox.   Ron
 NB Or
  	  | Quote: | 	 		  From: "Roger McConnell" <rdmac(at)swbell.net>
 Subject: Nose Wheel Shimmy
 Date: Mon, 29 May 2006 11:13:29 -0500
 reoccurring shimmy.
              Roger Mac
              S7/912s
 Is your PC infected? Get a FREE online computer virus scan from McAfee
 Security. http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
				 Posted: Tue May 30, 2006 10:32 am    Post subject: Nose Wheel Shimmy |
				Hi Roger,
 High speed shopping cart?  Can you balance the
 wheel/tire?
 Kurt S.
 --- Roger McConnell <rdmac(at)swbell.net> wrote:
  I have had a reoccurring shimmy......
		jdmcbean(at)cableone.net Guest
				 Posted: Tue May 30, 2006 8:23 pm    Post subject: Nose Wheel Shimmy |
				Roger,
 	The most common issue with the nose wheel shimmy is the strut axle nut.. it
 needs to be tight enough that it requires about 12-14 lbs of break away
 pressure if one was to grab the rear of the tire... You can adjust it by
 using a fish scale and hook it to the aft of the tire.  It does not need to
 maintain that pressure but it should be close to that to get the tire to
 start turning...
 Hope that helps...
 Fly Safe !!
 John & Debra McBean
 www.sportplanellc.com
 "The Sky is not the Limit...  It's a Playground"
				 Posted: Wed May 31, 2006 2:57 pm    Post subject: Nose Wheel Shimmy |
				John and others
 	Thanks for the advice; I do recall something in the build manual
 about using a fish scale. I'm not a fisherman so guess I'll borrow or go buy
 one. Now let's see if its 12-14 lbs at the rear of the tire what do you
 figure it to be at the rear of the faring? Think I'll try  6-8 lbs.
 	Roger Mac
 DO NOT ARCHIVE
		wingsdown(at)comcast.net Guest
				 Posted: Wed May 31, 2006 8:31 pm    Post subject: Nose Wheel Shimmy |
				I would not pull on the fairing that far aft....
 Fly Safe !!
 John & Debra McBean
		bnn(at)nethere.com Guest
				 Posted: Fri Jun 02, 2006 7:23 pm    Post subject: Nose Wheel Shimmy |
				At 09:13 AM 5/29/2006, you wrote:
  	  | Quote: | 	 		  Every sense installing the faring on the nose wheel, I have had a
 reoccurring shimmy.
 Wall occors its shimmyin'. Yur tryin' t fly the plane bakwards, dummy! The
 wheals sposed to be in da back!
 (Sorry, couldn't resist.)
 Guy Buchanan
 K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar.
		dan(at)azshowersolutions. Guest
				 Posted: Sat Jun 03, 2006 4:35 am    Post subject: Nose Wheel Shimmy |
				Guy,
   Ifin da wheel is sposed ta be in da back...why da heck duz it keep wantin ta moove roun to da frunt?
   Dan Billingsley
   Mesa
   Kitfox IV , 912s, TriGear
 reoccurring shimmy.
 Guy Buchanan
		dosmythe(at)cox.net Guest
				 Posted: Sat Jun 03, 2006 4:44 am    Post subject: Nose Wheel Shimmy |
				Good come back.  Couldn't help but laugh so early in the morning.
 Don Smythe
				 Posted: Sat Jun 03, 2006 11:18 am    Post subject: Nose Wheel Shimmy |
				At 05:31 AM 6/3/2006, you wrote:
  	  | Quote: | 	 		  Guy,
    Dan Billingsley
    Mesa
 HAHAHAHAHA! Thanks.
 (Tee hee.)
 Guy Buchanan
