sean(at)stephensville.com Guest
Posted: Wed May 23, 2012 2:33 pm Post subject: Matco Front Wheel and Desser Stem |
I was putting the front wheel together today. I have the Matco nose
wheel and Desser 500-5 tube with the TR-67 stem as recommended by many
others.
Where the stem goes through the rim, there are not enough threads to use
the locking nut to secure the stem to the rim. I've seen other pictures
where the locking nut is not even used. Has that been ok to skip?
-Sean #40303 (Prepping to put her on her legs)
philperry9
Posted: Wed May 23, 2012 2:39 pm Post subject: Matco Front Wheel and Desser Stem |
I have just had mine stuck through the hole, but I'm not happy with it either. Its something on my punch list before I go fly. But I sure don't like the way the valve comes through the opening and is completely unsecured.
Phil
On Wed, May 23, 2012 at 5:31 PM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
[quote] --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
I was putting the front wheel together today. I have the Matco nose wheel and Desser 500-5 tube with the TR-67 stem as recommended by many others.
Where the stem goes through the rim, there are not enough threads to use the locking nut to secure the stem to the rim. I've seen other pictures where the locking nut is not even used. Has that been ok to skip?
http://forums.matronics.com
le, List Admin.
