twinstar MK II thanks and another endless question
lmorgan100(at)charter.net
PostPosted: Mon May 28, 2012 4:13 am    Post subject: twinstar MK II thanks and another endless question Reply with quote
Thanks everyone for answering my W+B questions, I have another question.
I am filling out the W + B paperwork for the airworthiness certificate, in
the specs for the Kolb Twinstar MK II, it says total weight limit is 750
LBS. mine comes in at 814 lbs with two 170 lb people and 10 gallons of gas.
what do I do with this ?
thanks
Lee..
Thom Riddle
PostPosted: Mon May 28, 2012 12:20 pm    Post subject: Re: twinstar MK II thanks and another endless question Reply with quote
If you are the manufacturer, you get to establish the MTOW. The KIT manufacturer makes recommendations but the builder(manufacturer of complete aircraft) has the last word.
Even subsequent owners can change the MTOW of an experimental aircraft, with notification to FSDO and resuming phase 1 testing for some short period, in which you are supposed to verify that the aircraft is safe to fly at the new MTOW.
Anyone who has actually made this type of change, please correct me if I am wrong. I'm just relating what my FSDO told me when I asked the question.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
jackinkeywest
PostPosted: Tue May 29, 2012 5:33 am    Post subject: twinstar MK II thanks and another endless question Reply with quote
Hi Lee,
I may be about to 'stir up a hornet's nest' here but I think it's a risk worth taking in order to answer your question.
The kit manufacturer (Kolb Aircraft, Inc) sets the RECOMMENDED max gross/allowable weight for each model aircraft kit they produce. YOU, as the manufacturer/builder of said kit can set the max gross/allowable weight of YOUR aircraft to whatever weight you feel comfortable with.
Kolb recommends 750 lbs as the max weight. This is a limit they RECOMMEND and with that comes many variables (engineering calculations, liability concerns, etc.). That said, there is NOTHING to stop YOU from making your max weight limit on YOUR aircraft 800, 825, 850 or even 1000 LBS! What do YOU feel comfortable with knowing what the factory recommends?
If it were my aircraft and I built it per the plans without deviation, I would not hesitate to increase the max gross weight to 850 lbs given that most manufacturers use a 10-15% margin of error/caution in their favor mostly for liability reasons.
Let the firestorm begin....
Jack in Key West
cristalclear13
PostPosted: Tue May 29, 2012 10:28 am    Post subject: Re: twinstar MK II thanks and another endless question Reply with quote
thanks
Lee..
Lee,
My Mark II would also weigh that much with those specs. On my W&B I put that I have a max weight of 800lbs. On the Most Aft Loading I use 170lb pilot and 10 gallons of gas, on the Most Fwd Loading section I use 170lb pilot, 170lb passenger but less than 10 gallons to make it under the 800lb limit, then on the Flight Test Loading I put 195lb pilot and 6 gallons of fuel.
I have flown it with at least, if not a little more than, 850 lbs though and had no issues.
There should be a place on your W&B that says whether you got the data from the manufacturer or from your own data. You can put that you got it from your own data and as long as you test it out during your testing period, the kit manufacturer's weight limit does not come into the picture (as Jack and Thom also mentioned).
Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009
neilsenrm(at)gmail.com
PostPosted: Tue May 29, 2012 12:44 pm    Post subject: twinstar MK II thanks and another endless question Reply with quote
Lee
I'm not a big fan of betting that the factory is wrong on the weight limits. There are a lot of factors involved here. Do you know how well the plane was built? As a plane gets older some of the metal parts may fatigue and loose strength. Flying heavy and in rough air can increase the rate of fatigue. Some times corrosion can weaken parts. My plane spent six months in Florida. I couldn't believe how much corrosion developed in that salt air and it was hangered. Your MKII is a older model with a weaker air frame than the MKIII so don't confuse the weight limits set for the MKIII. You also have to use common sense that if you exceed the recommended limits you should only do it in calm air.
Yes you have the right to set the weight limits as you see fit. Just be sure, if you choose to fly much beyond the recommended limit, leave a record of what you did with someone on the ground so we can learn what the absolute limit was.
Again worth what you paid for it.
Rick Neilsen
Redrive VW Powered MKIIIC
On Tue, May 29, 2012 at 2:28 PM, cristalclear13 <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)> wrote:
[quote]--> Kolb-List message posted by: "cristalclear13" <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)>
> thanks
> Lee..
Lee,
Cristal Waters
Kolb Mark II Twinstar Rotax 503 DCSI  Sept 2007
http://forums.matronics.com/viewtopic.php?p=374200#374200
le, List Admin.
pj.ladd(at)btinternet.com
PostPosted: Wed May 30, 2012 10:13 am    Post subject: twinstar MK II thanks and another endless question Reply with quote
I'm not a big fan of betting that the factory is wrong on the weight limits>>
Hi,
I guess that in view of the litigious nature of American Society you all carry insurance.
What does the insurer say about flying outside the manufacturers limits? I would have expected them to use that as a reason for not paying out on a claim.
Cheers
Pat
PostPosted: Wed May 30, 2012 10:32 am    Post subject: twinstar MK II thanks and another endless question Reply with quote
claim.
Pat
The builder is the manufacturer.
hauck's holler, alabama
PostPosted: Wed May 30, 2012 11:05 am    Post subject: twinstar MK II thanks and another endless question Reply with quote
The builder is the manufacturer.>>
Hi John,
Hmmm. I would have thought that only pushes the liability back one step.
What is the situation if the manufacturer, or the builder as manufacturer
produces a plane which is obviously not airworthy. How do you get insurance?
Does the insurance company not apply any yardstick at all? How do they know
without inspection or testing if it will fly well, badly, or at all? I
understand that unlike the UK there is no such thing as an approved design
in the US. Who applies what standards in that case?
Curious
Pat
PostPosted: Wed May 30, 2012 11:47 am    Post subject: twinstar MK II thanks and another endless question Reply with quote
Curious
Pat
Patrick L/Gang:
In the amateur experimental/homebuilt class we must have our aircraft
inspected and issued an "airworthiness certificate", in addition to a 40
test flight period.
"How do I get insurance?" Obviously, I pay through the nose for it.
phactor9
PostPosted: Wed May 30, 2012 12:04 pm    Post subject: twinstar MK II thanks and another endless question Reply with quote
Speaking of insurance...
1. Who uses what insurance company?
2. What type of insurance do you subscribe to, or recommend?
3. What class bird? FAR-103? Other?
Phil H.
FF11-4-00076
--- On Wed, 5/30/12, John Hauck <jhauck(at)elmore.rr.com> wrote:
Subject: RE: Re: twinstar MK II thanks and another endless question
Date: Wednesday, May 30, 2012, 3:44 PM
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
Curious
Pat
Patrick L/Gang:
test flight period.
PostPosted: Wed May 30, 2012 12:16 pm    Post subject: twinstar MK II thanks and another endless question Reply with quote
Phil H.
Phil H/Gang:
1. Falcon, indorsed by EAA.
2. Hull, moving and stationary. Enough to replace my airplane should I
total it. Plus, 1,000,000.00 liability.
3. Experimental/homebuilt.
russk50(at)gmail.com
PostPosted: Wed May 30, 2012 2:25 pm    Post subject: twinstar MK II thanks and another endless question Reply with quote
PatI think it's safe to say we all TRY to carry insurance. But I'm also sure the ins co's in the UK are similar to ours here in the Colonies -- their attitude is to reject claims if at all possible, on most any excuse, then say "Thanks for the premiums, have a nice day, goodbye"
Russ
Hi,
Cheers
Pat
Thom Riddle
PostPosted: Wed May 30, 2012 3:27 pm    Post subject: Re: twinstar MK II thanks and another endless question Reply with quote
I carry liability and "not-in-flight" hull insurance which covers damage or loss to my Slingshot while on the ground except during take-off and landing. I have a policy with Global Aerospace which was obtained through EAA insurance affiliate, Falcon Insurance. Not paying for in-flight hull insurance saves me about $500-600/year. I figure if I crash it in flight the airplane repairs will be the least of my problems.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Richard Pike
PostPosted: Wed May 30, 2012 5:12 pm    Post subject: Re: twinstar MK II thanks and another endless question Reply with quote
<snip>
Does the insurance company not apply any yardstick at all? How do they know without inspection or testing if it will fly well, badly, or at all? I
Curious
Pat
Years ago I talked to a FAA man in that department about how they went about determining how to issue an Airworthiness Certificate to a problematic design. His answer was to the effect that you can design anything you want, but then you have to build it according to approved methods and practices. Assuming you build it well, but it is still a problematic design, he said they can issue you an Airworthiness Certificate with limitations that precludes you flying it more than 2' off the ground, or anywhere other than immediately above the runway.
In other words, if they don't think it will fly, they can restrict your flying to a minimum.
Never seen such a situation, but it makes sense to me -
Richard Pike
Kolb MKIII N420P (420ldPoops)
richard (at) bcchapel(dot)org
Kingsport, TN 3TN0
Now faith is the substance of things hoped for, the evidence of things not seen.
Hebrews 11:1
PostPosted: Thu May 31, 2012 4:56 am    Post subject: twinstar MK II thanks and another endless question Reply with quote
anywhere other than immediately above the runway. >>
Yeah! I guess that would do it as far as the Airworthiness Cert is concerned
but would any insurance company touch it?
You may roll it into a ball from 2 feet but suppose you flew it into a crowd
of people or parked aircraft at 2 feet.
Pat.
PostPosted: Thu May 31, 2012 5:07 am    Post subject: twinstar MK II thanks and another endless question Reply with quote
Hi Thom,
obviously you can get insurance flying a Kolb as you can point to a well
tried design and the Insurers can asses the risk from their records. What
happens if you put a jet engine on it, turn it into a twin, redesign and fit
a twin fin and rudder.? Even if you are the manufacturer and can set what
parameters you like you may have no aerodesign or engineering skill
whatever. I would have thought the insurers wouldn`t touch it with a barge
pole. Then you fly it into someone, or their plane. . You could be in Sing
Sing for the rest of your natural. Certainly in Bankruptcy Court.
Shudder!
Pat
PostPosted: Thu May 31, 2012 5:36 am    Post subject: twinstar MK II thanks and another endless question Reply with quote
their attitude is to reject claims if at all possible>>
Hi Russ,
I am sure that is true but speak as I find. When I flew into the barn through starting the engine when the throttle was open the insurance Company sent an assessor .It was obvious that the starboard wing had to be rebuilt. There was some discussion over possible twisting of the cage due to the backwards movement of the wing. This was decided in consultation with the Inspector and the cage was condemned. This meant a total strip of instruments etc and rebuild of the whole front end. Including the car I managed to drive the nose cone into I think that the bill was in excess of 20,000 pounds. The insurers paid up with no quibble.
On the other hand my partner, when we had the Aerostar, was always worried because if the two of us took off with a full fuel load we were above the certified weight. The problem was not that the plane wouldn`t handle it but because if we took off overweight we were no longer classed as a `microlight` and we were into a whole new ballgame. We were a Light Aircraft and therefore outside our insured category
He was afraid that if we crunched it was a fairly simple matter to back calculate what our take off weight had been and that would be used to let the insurers of the hook.
Incidentally I employed a couple of guys from the local carwash to wash my plane yesterday. Just to smarten it up before the prospective buyers start lining up to view it.
There are hundreds of teams of men all over the UK who have moved into disused garage sites and set up car washes. Of course the garages had sumps already built to in to stop oil and muck going down the drains. Electricity and water were laid on. Just waiting for someone to find a use for them. These guys are usually Polish. I know one lot who are Lithuanians and the guys I used are, would you believe it from Iraq.
They all do a fast and reasonably priced job.It is not easy as they are in the cold and wet all day, usually no resting facilities or shelter if it pours. I am sure the income tax is being wangled as no one knows how much money they take in a day.. Probably all sorts of `elf and safety issues being ignored as well.
We have several million unemployed in the UK but I have not found a team of car washers who are English. Makes you think.
Cheers
Pat
