Converting an, O-320A1A to an O-320 A2B
gentryll
PostPosted: Thu May 31, 2012 11:12 am    Post subject: Converting an, O-320A1A to an O-320 A2B Reply with quote
I have a complete A1A with no logs. I also have an A2B logbook, data plate, cylinders, and case. I would like to have the two put together to have a certified A2B to install in a PA22/20. The only difference I see in the parts in the Lycoming manual are "straight riser in oil sump and type-32 carb. What does straight riser mean and how does that differ from the riser in the A1A. Is the riser the oil tube from the sump to the pump. Will my A1A sump work in an A2B?
