elleryweld(at)aol.com Guest
Posted: Sat Jun 09, 2012 11:14 am Post subject: Jim Feldmann Prop Failure |
I just happen to notice you had a prop failure what Prop was it ?and what was the problem with it? if you dont mind me asking .
I had a Warp Drive fail on me it delaminated in flight Lost an airplane over it never again a warp for me
Ellery Batchelder Jr.
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Jim Feldmann
Posted: Sun Jun 10, 2012 7:59 am Post subject: Re: Jim Feldmann Prop Failure |
Regarding your question about my prop failure; it was a 2 year old GSC 3 blade. All three blades departed the hub at the same time while cruising at about 2600 feet.
The NTSB studied the remains (all three blades were found within 30 feet of each other on the ground) and could find no apparent cause.
My Kitfox was heavily damaged in the off field landing, but there were no injuriies.
_________________ Jim Feldmann
Kitfox IV Speedster / 912 lost to prop failure
Building a Kitfox 5 Voyager
Last edited by Jim Feldmann on Sun Jun 10, 2012 10:17 am; edited 1 time in total |
rparigoris
Posted: Sun Jun 10, 2012 8:13 am Post subject: Jim Feldmann Prop Failure |
Hi Jim
Sorry to hear about your prop failure.
Curious, did your 912 overspeed and hurt itself?
If so what exactly got hurt?
Thx.
Ron Parigoris [quote][b]
BARRY CHECK 6
Posted: Sun Jun 10, 2012 8:14 am Post subject: Jim Feldmann Prop Failure |
Jim:
There was a SB... Only because they do not write AD's for�experimental's. �About blade�separation�at the hub.�You may find this information on the manufacturer's web site or under the FAA's AD List (Manufactures). �The engine should also be treated as if it had a Prop-Strike. �
Barry
On Sun, Jun 10, 2012 at 11:59 AM, Jim Feldmann <feldesign(at)earthlink.net (feldesign(at)earthlink.net)> wrote:
[quote]--> RotaxEngines-List message posted by: "Jim Feldmann" <feldesign(at)earthlink.net (feldesign(at)earthlink.net)>
Regarding your question about my prop failure; it was a 2 year old GSC 3 blade. �All three blades departed the hub at the same time while cruising at about 2600 feet.
The NYSB studied the remains (all three blades were found within 30 feet of each other on the ground) and could find no apparent cause.
Jim Feldmann
Looking for a project
http://forums.matronics.com/viewtopic.php?p=375201#375201
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
Jim Feldmann
Posted: Sun Jun 10, 2012 10:12 am Post subject: Re: Jim Feldmann Prop Failure |
There was a single hard shake/knock/bang and the engine stopped. We discovered that that it instantly shook both carbs off. We did not think that there was an overspeed, but the wreck, including the engine, was sold at auction, so I don't know for sure.
Two practicing A+E's, one of whom was in the airplane when it happened, felt that the engine probably did not sustain any damage, but the buyer got it cheap enough to afford a rebuild so hopefully he did it.
Building a Kitfox 5 Voyager |
Jim Feldmann
Posted: Sun Jun 10, 2012 10:23 am Post subject: Re: Jim Feldmann Prop Failure |
Barry:
I read the SB. The gap between the front and rear halves of the hub was within spec, but I was not the original owner, so according to the SB I should have sent it to GSC for inspection. I did not. That is the specific reason why I did not sue GSC.
Posted: Sun Jun 10, 2012 6:25 pm Post subject: Jim Feldmann Prop Failure |
thanks for the info so I can add that to the list of props I wont buy ever again so I dont get another bad prop
