samira.h(at)shaw.ca Guest
Posted: Thu Jun 21, 2012 3:34 am Post subject: Cyl. Head Temperature Delta |
Does anybody know the cylinder head
temperature delta on YAK/Nanchang
engines between jug #1 and #4?
I always was under the impression
cylinder #4 runs the coolest due the
master rod but my gauges indicate
otherwise.
Thank you in advance.
cheers
Elmar
Posted: Thu Jun 21, 2012 3:53 am Post subject: Cyl. Head Temperature Delta |
Elmar,
I'm curious why you thought the cylinder with the master rod would run
cooler?
On the Yak 52's M14, my experience has been the upper cylinders,
typically 9, 1, 2 run a bit hotter than the other cylinders. I don't
remember the exact delta, but I do remember they always were hotter.
The readings were taken with a laser temperature probe. This may be due
to the fact that these cylinder are tucked behind the shroud on the top
of the cooling louver ring.
Now folks like Terry Slawinski that have the JPI 9 cylinder engine
analyzer would probably have much more accurate information since it
reads both CHT and EGT on all 9 cylinders.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 6/21/2012 6:31 AM, Elmar & Manuela Hegenauer wrote:
<samira.h(at)shaw.ca>
otherwise.
cheers
Elmar
Dale
Posted: Thu Jun 21, 2012 5:43 am Post subject: Re: Cyl. Head Temperature Delta |
5 and 6 run the coolest followed by 4 and 7 then 3 and 8 then 9 , 1,2.
I think it's because the air can leave easily in the yak at least around the exhaust pipe exist and the air going around the oil sump has a easy path out the bottom. also the fuel gets pumped into the bottom of the engine and the first cyls to get a bite are the bottom ones. My JPI shows it like a bell curve . 9 and 1 are always the hottest 5 and 6 always the coolest. I have fuel injection so my numbers will not be something you could use only as a reference. and my plane does not have a cooling shroud.
Posted: Thu Jun 21, 2012 7:02 am Post subject: Cyl. Head Temperature Delta |
Based on a conversation I had this morning with Barrett Precision
Engines on this subject, the primary reason the lower cylinders run
cooler is because the fuel is vaporized better in the lower cylinders
than the upper cylinders. They have proven this in the test chamber
with their "mule" engine with the engine fully instrumented and running
both their fuel injection system AND with the standard carburetor.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
On 6/21/2012 8:43 AM, Dale wrote:
5 and 6 run the coolest followed by 4 and 7 then 3 and 8 then 9 and 1.
http://forums.matronics.com/viewtopic.php?p=376205#376205
jan.mevis(at)informavia.b Guest
Posted: Thu Jun 21, 2012 7:25 am Post subject: Cyl. Head Temperature Delta |
I've Aerospace Logic CHT probes on the front plugs of my M14R.
First thing: the temperatures that I measure on the front plug nr 4 are 35
degrees colder than the number 4 plug on the rear (CHT indicator of the
plane which I assume is correct).
Then indeed, cyl 6 is the coldest on my engine, closely followed by the nr
5.
But nr 3 is the hottest, immediately followed by nr 4. And the difference
between 6 and 3 goes up to 40, 45 degrees Celsius. On my engine, different
regimes, the number 3 always ends up being the hottest.
I don't have any precise data yet (figuring out a way how to copy them
while flying, but there's a serial data line on the instrument).
Jan
On 21/06/12 16:58, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net>
wrote:
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
>always the coolest.
Dale
Posted: Thu Jun 21, 2012 7:33 am Post subject: Re: Cyl. Head Temperature Delta |
During my loooong dealings with this matter I also learned that apparently the intake pipes in relation to the fuel delivery from the carb has a direct effect on the M-14 . Some US radial engine makers offset the intakes in relation to the initial fuel air delivery to so-call bypass some of the cylinders to even out the spread of fuel in a attempt to minimize this issue.
Posted: Thu Jun 21, 2012 10:25 am Post subject: Cyl. Head Temperature Delta |
Hi again,
thank you very much for your input
and thoughts on this matter, much
appreciated.
Years ago someone on the list stated
that cylinder No. 4 runs the coolest
due the greater mass of the master rod,
hence better heat dissipation.
My extension leads were decayed to a
degree where replacement was absolutely
necessary.
I couldn't find any original leads (russian
GOST standard) so I had to buy US CHT
gauges including extensions and thermocouples.
These have been installed according to
the maintenance book - front cockpit
gauges connected to cyl. #4 and rear
cockpit to cyl. #1.
Now my gauges show a delta of 25 degrees
Celsius with no. 4 being the hotter one.
Thanks again and Blue Skies.
cheers
Elmar
Posted: Thu Jun 21, 2012 10:44 am Post subject: Cyl. Head Temperature Delta |
This is also in the line of what I see: 4 is the second hottest, and 1 is
in between the coldest (nr 6) and the hottest (nr 3).
So this delta of 25 degrees is also what I measure, (with a difference of
a few degrees).
Jan
On 21/06/12 20:22, "Elmar & Manuela Hegenauer" <samira.h(at)shaw.ca> wrote:
Hi again,
appreciated.
necessary.
cockpit to cyl. #1.
cheers
Elmar
dougsappllc(at)gmail.com Guest
Posted: Thu Jun 21, 2012 10:49 am Post subject: Cyl. Head Temperature Delta |
Elmar,I stock P/N 5SH.422.001 which is the Chinese CHT thermo couple lead, 7 feet long. It has the connections on one end to accept the CHT probe wires and has the gauge plug on the other end.
Best,
Doug
On Thu, Jun 21, 2012 at 11:22 AM, Elmar & Manuela Hegenauer <samira.h(at)shaw.ca (samira.h(at)shaw.ca)> wrote:
[quote]--> Yak-List message posted by: Elmar & Manuela Hegenauer <samira.h(at)shaw.ca (samira.h(at)shaw.ca)>
Hi again,
appreciated.
necessary.
cockpit to cyl. #1.
cheers
Elmar
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
PaulW
Posted: Wed Oct 28, 2015 8:55 am Post subject: Re: Cyl. Head Temperature Delta |
Hi
I have been looking and Googling, but cannot find the info I need. I am sure someone here will know.
1. Where is the CHT sensor fitted? I read somewhere at the hottest and coldest cylinder. So there are two? Also read it is close to the rear sparkplug?
2. Which cylinder is which? How do you count if you are in front or rear? I know 1 is at the top, but which one exactly and which direction do you start counting?
threein60(at)yahoo.com Guest
Posted: Wed Oct 28, 2015 10:39 am Post subject: Cyl. Head Temperature Delta |
I believe most radials have it installed on the number four or which ever is the master rod.Larry
Sent from Yahoo Mail on Android From:"PaulW" <paul(at)budcyber.com>
Date:Wed, Oct 28, 2015 at 10:17
Subject:Re: Cyl. Head Temperature Delta
--> Yak-List message posted by: "PaulW" <[url=javascript:return]paul(at)budcyber.com[/url]>
Hi
http://forums.matronics.com/viewtopic.php?p=44"http://www.matronics.com/Navigator?Yak-List" target="_blank">http://www.= -->
Posted: Wed Oct 28, 2015 2:12 pm Post subject: Cyl. Head Temperature Delta |
CHT probes are under the rear spark plugs. On the Yak 52, both are under #4. (Some people split them between 3 and 4). On the CJ they are typically split between two rear plugs. #4 and #3 or possibly #2. They are easy to see. Look for a wrapped wire bundle going to the rear plugs.
Looking at the front of the engine, Cylinder number 1 is at the very top. looking at the front of the engine, count clockwise 1,2,3,4,5 then the sum, 6,7,8,9.
Dennis
To: yak-list(at)matronics.com
Sent: Wednesday, October 28, 2015 12:55 PM
Subject: Re: Cyl. Head Temperature Delta
--> Yak-List message posted by: "PaulW" <paul(at)budcyber.com (paul(at)budcyber.com)>
Hi
http://forums.matronics.com/viewtopic.php?p=448330#448========================http://www.matronics.com/Navigator?Yak-List<; http://forums.sp; - List Contribution Web Site -
_; &nb://www.matronics.com/contribution" target="_blank">http://www.matronics.c===================
wlannon(at)shaw.ca Guest
Posted: Wed Oct 28, 2015 4:38 pm Post subject: Cyl. Head Temperature Delta |
Cj6, Yk50, 52, Or??
Ttail
PaulW
Posted: Thu Oct 29, 2015 2:11 am Post subject: Re: Cyl. Head Temperature Delta |
| wlannon(at)shaw.ca wrote: | Cj6, Yk50, 52, Or??
My bad
Yak-52 M-14P.
Thank you to those who responded, that will help.
Ttail, that is a big difference between the pods. Am I reading it correctly? The one with arrow (7) is 199deg C and the others thus higher?
What is the highest? Can't make it out on the photo.
What I noticed on the last flight and I am not sure whether I am imagining things, but it felt like the cockpit was warmer than normal, after stopping engine and climbing out and walking around the YAK, that the left as standing in front of the plane is warmer than the left.
Is that normal?
That is why I thought I'd like to check the temperature probes, where they are, etc.
If it is measuring the coolest cylinder, some of the others may become very hot indeed even if the coolest is still in spec on the CHT gauge.
I don't have a monitor system to measure each cylinder. Pretty much a stock YAK.
What I also found is that it is smoking a bit while on idle even after flight from righthand side exhaust plus the righthand side exhaust have a little oil on the outside which come from between the most bottom piece and the next one up, ie most bottom joint. But it doesn't look like the normal oil that is black and drip out of the exhaust when stationary, so it could be smoke system oil, but I somehow doubt it. Smoke system off and still oil doesn't seem possible.
AMO reckons rings might need to be replaced.
Posted: Thu Oct 29, 2015 3:02 am Post subject: Cyl. Head Temperature Delta |
Then both CHT's are typically on the #4 rear plug.
Dennis
Sent: Thursday, October 29, 2015 6:11 AM
| Quote: | Cj6, Yk50, 52, Or??
My bad [Embarassed]
Yak-52 M-14P.
Is that normal?
http://forums.matronics.cotp://www.matronics.com/Navigator?Yak-List" target="_blank">http://www.mat --> [quote][b]
