dutrac
Posted: Thu Jun 21, 2012 2:35 pm Post subject: Landing gear (axle material) |
Hi Folks,
I have a Kolb MKII that I've given a few hard landings. The axles have bent and I've used a hydrolic press to straighten them once. After doing so it wasn't but a couple landings later that I noticed they were pretty well bent again.
I talked to a factory rep and he told me that they don't recommend straightening them more than once. Whether right or wrong, I'm going to listen to that advice and replace them both.
My question to the group then is what grade of aluminum are the axles made out of?
Any help is appreciated.
Thanks!
Duane
rickofudall
Posted: Thu Jun 21, 2012 2:41 pm Post subject: Landing gear (axle material) |
7075-T6
Rick Girard
On Thu, Jun 21, 2012 at 5:35 PM, dutrac <dlrans(at)gmail.com (dlrans(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "dutrac" <dlrans(at)gmail.com (dlrans(at)gmail.com)>
Hi Folks,
Thanks!
Duane
http://forums.matronics.com/viewtopic.php?p=376255#376255
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
captainron1(at)cox.net Guest
Posted: Sat Jun 23, 2012 12:43 pm Post subject: Landing gear (axle material) |
those are 7075 aluminum, you better off either designing your own or getting the steel ones from the facto
ron (at) KFFL
---- dutrac <dlrans(at)gmail.com> wrote:
Hi Folks,
Thanks!
Duane
Ron (at) KFHU
kolbaircraft
Posted: Mon Jun 25, 2012 11:45 am Post subject: Re: Landing gear (axle material) |
The material is 7075 T651 MII would be 1.250 dia. on top
Travis
Kolb CO.
capedavis(at)yahoo.com Guest
Posted: Mon Jun 25, 2012 5:06 pm Post subject: Landing gear (axle material) |
Travis and all , Isn't that the gear legs you are talking about not the axle ? arent the axles Chromemoly? Not Aluminum
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
From: kolbaircraft <customersupport(at)tnkolbaircraft.com>
Sent: Monday, June 25, 2012 3:45 PM
Subject: Re: Landing gear (axle material)
--> Kolb-List message posted by: "kolbaircraft" <customersupport(at)tnkolbaircraft.com (customersupport(at)tnkolbaircraft.com)>
Travis
Kolb CO.
http://forums.matronics.com/viewtopic.php?p=376585#376585
Un/Subscription,Photoshare, and much much more:
href="http://www.matronics.com/Navigator?Kolb-List" target=_blank>httpbsp; -Matt
