Engine out..deadstick landing required..question on hea
kitfoxjunky(at)decisionla
PostPosted: Mon Jun 25, 2012 11:55 am    Post subject: Engine out..deadstick landing required..question on hea Reply with quote
To say this is a KF 3 is a bit of a stretch. Looks to me like a cobble together bag of Kitfox parts.
Fuel system is definitely non-standard.
Thx for the info.
Gary Walsh
KF IV Anphib 912S
C-GOOT
[url=sans-serif]www.decisionlabs.com/kitfox[/url]
kerrjohna(at)comcast.net
Sent by: owner-kitfox-list-server(at)matronics.com
06/25/2012 01:44 PM
Please respond to kitfox-list
cc:
Subject: Re: Engine out..deadstick landing required..question on header tank location
Normal fuel line design does not have the ability to switch tanks. An individually designed system does not benefit from the experience of thousands of Kitfoxes out there. Some have tried to eliminate "one tank low" but there is little evidence of anyone actually experiencing fuel starvation with the standard arrangement. There have been reports of starvation when tanks are individually controlled.
Good luck.
John
To:
kitfox-list(at)matronics.com
Sent:
Monday, June 25, 2012 11:06:10 AM
Subject:
On 6/25/2012 9:51 AM, [url=Arial]kitfoxjunky(at)decisionlabs.com[/url] wrote:
The airplane has flown for several hours since the engine failure. All of it over the home strip. Maybe it actually was bad gas.
Can't imagine "bad gas". Water, yes. Sediment, unlikely. Since it happened when he switched tanks he could still be feeding off the "good" full tank, though I would hope he's seeing flow in both tanks as he flies, or maybe is switching back and forth between tanks.
The pulse line is not your typical plastic tube. Most 1/4" fuel line has a wall about 3/32" thick. Pulse line has about an 1/8" plus wall thickness. The thin line dampens the pulses, weakening the fuel pump action.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded
Now a glider pilot, too.
FORUMS -
Site -
-Matt Dralle, List Admin.
