Resistance fuel senders to 2 gauges
peter(at)sportingaero.com
PostPosted: Thu Jun 28, 2012 2:15 pm    Post subject: Resistance fuel senders to 2 gauges Reply with quote
Guys,
I've recently re-built my panel and added an EFIS, updated the radios,
taken out the Expbus2 and included an endurance bus. As I already had a
pair of fuel gauges I thought I would retain them to avoid booting the
EFIS when I wanted to find out how much fuel is loaded before flight. I
have regular resistance fuel senders and wired the gauges in parallel
with the EFIS. I should have realised that the apparent resistance now
seen by the fuel gauges has decreased, so their reading decreases when
the EFIS is switched on. This isn't a problem for the EFIS as I can
calibrate them accordingly. But it would be good if the fuel gauges were
more accurate when the EFIS is on.
So my question is, is there a straight forward way to share a resistance
sender with 2 gauges without impacting the calibration of either gauge?
Peter
PostPosted: Thu Jun 28, 2012 6:53 pm    Post subject: Resistance fuel senders to 2 gauges Reply with quote
At 05:13 PM 6/28/2012, you wrote:
<peter(at)sportingaero.com>
Guys,
radios, taken out the Expbus2 and included an endurance bus. As I
already had a pair of fuel gauges I thought I would retain them to
avoid booting the EFIS when I wanted to find out how much fuel is
loaded before flight. I have regular resistance fuel senders and
wired the gauges in parallel with the EFIS. I should have realised
that the apparent resistance now seen by the fuel gauges has
decreased, so their reading decreases when the EFIS is switched on.
This isn't a problem for the EFIS as I can calibrate them
accordingly. But it would be good if the fuel gauges were more
resistance sender with 2 gauges without impacting the calibration of
either gauge?
Variable resistor transducers must be "powered up"
by their mated instrument. When you tie two resistance
measurement instruments onto the same sensor, their
"power up biases" add together and upsets the readings
of both.
What you'll need to do is tell the EFIS to work on
a variable VOLTAGE input and turn off it's internal
excitation of the remote sensor. Then allow the
original instrument to POWER the transducer. Finally
teach the EFIS how to read it.
racerjerry
PostPosted: Sat Jun 30, 2012 2:46 am    Post subject: Re: Resistance fuel senders to 2 gauges Reply with quote
DPDT toggle switch from sender?
Jerry King
PostPosted: Sun Jul 01, 2012 2:21 pm    Post subject: Resistance fuel senders to 2 gauges Reply with quote
Of course, the large assumption I made was that the EFIS and the fuel
gauges operate at the same voltage - which they do not ... So now I have
a pair of u/s fuel gauging circuits within the EFIS which will have to
be returned to the manufacturer for repair.
I guess the moral is when you think you are being really smart, you have
probably missed something and are about to be really dumb.
Peter
On 29/06/2012 03:50, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
Guys,
a pair of fuel gauges I thought I would retain them to avoid booting
the EFIS when I wanted to find out how much fuel is loaded before
flight. I have regular resistance fuel senders and wired the gauges in
parallel with the EFIS. I should have realised that the apparent
resistance now seen by the fuel gauges has decreased, so their reading
decreases when the EFIS is switched on. This isn't a problem for the
EFIS as I can calibrate them accordingly. But it would be good if the
fuel gauges were more accurate when the EFIS is on.
either gauge?
of both.
millner(at)me.com
PostPosted: Sun Jul 01, 2012 7:48 pm    Post subject: Resistance fuel senders to 2 gauges Reply with quote
Probably not very good human factors to get used to looking at a fuel
gage that reads "empty" as being normal...
Paul
