AirEupora
Posted: Sat Jun 30, 2012 8:27 pm Post subject: MGL Odyessey connected to Jabiru 3300 |
Just reviewing my flight log on my first -through fourth flight and found a couple of things that I had set up wrong in the MGL Odysseys. My oil pressure looks low on the black box print out and I'm thinking that I have the wrong sensor in the program. Does anybody know the type of sensor that the Jabiru 3300L has installed. I only have a single outlet (wire blade)
I can put the following types into the program:
1. automotive: resistive; 200 ohm or 400 ohms
2. linear, voltage 0.5- 4.5v
3. Rotax 4- 30mA
4. Linear, voltage 0-5v
selwyn
Posted: Wed Jul 18, 2012 1:35 am Post subject: Re: MGL Odyessey connected to Jabiru 3300 |
It is automotive resistive and (I think) 400 ohm. I can check if you like but the value you get should tell you pretty quickly. My 3300A runs low - mid 30's psi when hot.
_________________ Cheers, Selwyn
Kit 66 VH-ELZ |
AirEupora
Posted: Thu Jul 19, 2012 7:07 am Post subject: Re: MGL Odyessey connected to Jabiru 3300 |
Thanks, i was able to get a hold of Matt at KTOA. I have set the Ohms at 200. It is working great.
