Roland
Posted: Sun Jul 15, 2012 9:09 pm Post subject: Rotax 914 - how to avoid an overboost? |
Friends,
I had bad luck with my Rotax 914 some weeks ago. The TCU unit had a comoplete electricity failure due to a damaged automatic circuit breaker. All normal during run up - no electricity - no TCU warning lights. Select full T/O-power, suffered an overboost, cracked crankcase - 10k Euro damage - ouch!
If the TCU-lights don't illuminate by switching the master on - okay, then you have a chance to be aware of the dawning danger. At any other time no chance at all from my point of view.
Do I get something wrong here or is it a design fault of the Rotax? Argument of sufficient power all time not applicable due to no power at all with cracked crankcase - lucky me I was not airborne yet....
Any comments most welcome.
Grounded Roland
PH-ZTI
XS Trigear 914
Posted: Mon Jul 16, 2012 1:15 am Post subject: Rotax 914 - how to avoid an overboost? |
On 07/16/2012 07:09 AM, Roland wrote:
| Quote: | Do I get something wrong here or is it a design fault of the Rotax?
I'm afraid you did something wrong...
You are not supposed to take off when the warning lights do not come on.
Furthermore you are supposed to watch the manifold pressure gauge when
you select T/O power.
Note that what you experienced was the worst scenario: Apparently the
last known state of the engine was at low power or switched off and thus
with the waste gate fully closed, and you applied full power without the
TCU available to open the waste gate, with an extreme overboost as a result.
During flight nothing dramatic will happen when the TCU suddenly fails,
as the waste gate will stay on its most recent setting, which is correct
for your selected power and atmospheric pressure. Depending on the
throttle setting and altitude you will either experience some loss of
power or a mild overboost when changing the throttle setting or changing
altitude. It should get you home safely.
Sorry to hear your misfortune...
Frans
Roland
Posted: Mon Jul 16, 2012 4:59 am Post subject: Re: Rotax 914 - how to avoid an overboost? |
Frans,
thanks for your sympathies and comments on this which of course are much appreciated.
Principally I agree with all you are saying,
But: electricity can be lost at any time, so everything might be looking good on start up. You can encounter the same problem during taxi or run up (like me) or in the descend, when the waste gate is also fully closed. Select full power on a go around and you have it as well - with no warning lights at all.
Watching the manifold can be an option, but believe me that you have an overboost within a second or two with T/O-power and the gate fully closed - so you have to be very quick. I also doubt, that you have your eyes on this the first seconds in a go around situation.
Roland
PH-ZTI
XS Trigear 914
Posted: Mon Jul 16, 2012 6:12 am Post subject: Rotax 914 - how to avoid an overboost? |
Roland a écrit :
| Quote: | Watching the manifold can be an option, but believe me that you have an overboost within a second or two with T/O-power and the gate fully closed - so you have to be very quick. I also doubt, that you have your eyes on this the first seconds in a go around situation.
Roland and all,
As a flight instructor and Rotax 914 homebuilder and flyer, I would
strongly insist on monitoring engine parameters (viz manifold pressure
and rpm) when setting takeoff/go around power. It is naturally easier
with conventional gauges with clear legal redlines : one gets quickly
used to watch the needles reaching the redline from the corner of one's eye.
Also, what is definitely needed in a "electrically dependant" aircraft,
is a conspicuous under voltage warning light.
My best sympathy for your mishap,
Best regards,
Gilles
http://contrails.free.fr
rlborger(at)mac.com Guest
Posted: Mon Jul 16, 2012 6:38 am Post subject: Rotax 914 - how to avoid an overboost? |
914 folks,
I'm not sure another buzzer/warning light is sufficient. I have the GRT EIS400 and you can set an acceptable operating range for just about every parameter the EIS measures and displays. When any parameter goes out of range you have a noise in the headset, the RED master warning light illuminates and the EIS display shows a flashing out of range parameter value.
So you apply throttle on go-around for some reason that already has your attention and you get buzzing and flashing, oh crap, what's wrong... You look to see what the display is flashing and finally figure out that it's showing 45" of boost and you reach for the throttle. By that time something has already broken.
Giles has the best remedy. Any time you advance the throttle, you should be watching manifold pressure. The throttle is used to control MP on an aircraft with a C/S prop. When you reach for the throttle, you should be doing it to set a specific MP so you should be watching MP. Now that could be difficult to do when you are already preoccupied with another problem situation that has required an increase in power, but it should still be Throttle-MP.
Just my 2¢. Take it for what it's worth.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
On Jul 16, 2012, at 8:25 AM, Peter Zutrauen wrote:
Sounds like a separate/dedicated high-manifold pressure alarm cct with buzzer/indicator may be warranted?
Cheers,
Pete
Posted: Mon Jul 16, 2012 7:20 am Post subject: Rotax 914 - how to avoid an overboost? |
On 07/16/2012 04:11 PM, Gilles Thesee wrote:
| Quote: | As a flight instructor and Rotax 914 homebuilder and flyer, I would
eye.
I have quite a few instruments in my modified full width panel. But the
upper three holes are occupied by three conventional gauges: 1) the
manifold pressure, 2) the fuel pressure, 3) the RPM gauge.
These are the only instruments I monitor briefly during the T/O. And as
you say, a needle in some colored zone in a familiar angle can be
absorbed in the blink of an eye, much faster than reading a number and
interpreting its value.
Other instruments are located further down in the panel. Issues like
overtemperatures or even loss of oil pressure can wait until at least a
survivable altitude has been reached.
Further I agree that during a go around it is the worst time to have a
failure of something. I don't think you can safeguard against anything.
A warning light or buzzer would be meaningless in such a situation,
unless of course the go around is optional, but then what was the
purpose of the go around anyway?
The only time I executed a go around was when I was on an announced
short final upwind, while suddenly a twin engine aircraft emerged over
the top of the hill and decided to perform a downwind landing on the
same runway. Not sure what I would have done during an overboost, but
probably I would have opted to get out of there anyway. I don't remember
looking at the gauges I have to admit. Just what I said, some risks are
unavoidable.
Frans
Posted: Tue Jul 17, 2012 4:25 am Post subject: Rotax 914 - how to avoid an overboost? |
PHILLIPS I a écrit :
I normally switch on my dedicated CB for the waist gate servo as part
of my check list as soon as I get in the cockpit, But on one occasion
because I was distracted by
Ground crew I totally forgot to check,
Half way down the runway gets a loud over boost warning from the Dynon
EMS 10
Ivor,
Your message seems to imply you disconnect the TCU/turbo CB when on the
ground. Just out of curiosity, is that so, and what purpose exactly is
that for ?
Doesn't the master switch suffice to turn off everything in the ship ?
Best regards,
Gilles
Ivor Phillips
Posted: Tue Jul 17, 2012 7:40 am Post subject: Rotax 914 - how to avoid an overboost? |
Hi Gilles
I decided early on in my wiring to make sure that the waist gate servo and ECU always had power, So I have wired it direct bi passing the battery contactor,
It has a klixon CB that is always pulled after shutdown,
Normally the first thing I do when climbing aboard is to push home the CB
And listen for the servo to go through its start sequence and check the warning
Lights,
I also have a toggle switch for the same circuit but that is normally left on with
A further single action push switch dedicated to the servo, only used in case of hunting,
The moral of the story is when interrupted for any reason doing your checklist
Go back to the start,
On 17 July 2012 13:24, Gilles Thesee <Gilles.Thesee(at)ac-grenoble.fr (Gilles.Thesee(at)ac-grenoble.fr)> wrote:
[quote] --> Europa-List message posted by: Gilles Thesee <Gilles.Thesee(at)ac-grenoble.fr (Gilles.Thesee(at)ac-grenoble.fr)>
I normally switch on my dedicated CB for the waist gate servo as part of my check list as soon as I get in the cockpit, But on one occasion because I was distracted by
Half way down the runway gets a loud over boost warning from the Dynon EMS 10
Ivor,
Your message seems to imply you disconnect the TCU/turbo CB when on the ground. Just out of curiosity, is that so, and what purpose exactly is that for ?
Best regards,
Gilles
target="_blank">http://www.matronics.com/Navigator?Europa-List
http://forums.matronics.com
le, List Admin.
Posted: Tue Jul 17, 2012 8:18 am Post subject: Rotax 914 - how to avoid an overboost? |
Hi Gilles
battery contactor,
the warning
Lights,
left on with
in case of hunting,
checklist
Ivor,
Understand, thank you for your response.
We followed the same line of thought, but our TCU is fed through an
Essential/Endurance bus. The auxilliary pump is fed direct from the aux
battery (with a 'forget me not' buzzer when the engine does not run, to
help prevent draining the battery after shutdown).
Best regards,
Gilles
Posted: Tue Jul 17, 2012 1:29 pm Post subject: Rotax 914 - how to avoid an overboost? |
On 07/17/2012 05:39 PM, PHILLIPS I wrote:
| Quote: | I decided early on in my wiring to make sure that the waist gate servo
battery contactor,
Just like some people like the stall warner, the trim servo, and some
other bunch of "recommended execptions" bypassing the master switch?
My thought here is that everything could be essential in some stage of
the flight, but then what is the meaning of the master switch if half
the ship is bypassing it?
I want the master switch do exactly what it is supposed to do, to power
down the ship completely. If I want to retain power on the TCU, the
stall warner, the trim servo, or whatever, I just don't power down. Am I
missing something here?
You have already experienced how such an exception can turn against you.
Everything that is wired apart from the master switch can be forgotten
to be switched on, and can fail just as easily as the master switch. In
an unavoidable crash situation, where you have to land in hostile
terrain, it is highly desirable that you can power down the electrical
system with just one switch, without having to think (or worry) about
all the exceptions which are bypassing the master switch and keep their
sparking abilities when ripping the fuel tank is a possibility.
| Quote: | It has a klixon CB that is always pulled after shutdown,
These things are not supposed to be used as a switch (please read the
manufacturer technical manual). They will fail, much sooner than an
ordinary switch, if you regularly pull them. There is a quite
complicated mechanism behind these things and repeated use will wear
them out quickly. So, there again, it might turn against you.
I never quite understood why folks want to bypass the master switch.
What is the reason behing it?
Is it just me thinking like this about the purpose of the master switch?
Frans
Fred Klein
Posted: Tue Jul 17, 2012 2:10 pm Post subject: Rotax 914 - how to avoid an overboost? |
On Jul 17, 2012, at 3:21 PM, Frans Veldman wrote:
| Quote: | | Is it just me thinking like this about the purpose of the master switch? |
I'm w/ you Frans...what kind of "Master" allows for independent choices?...
Years ago, when I added a 12 hp go cart engine to my foot-launched, tail-less biplane glider, the "Master" kill switch was in my mouth...opening the circuit was as simple as relaxing my jaw or opening my mouth...of course there were some intrepid flyers...who, when frozen w/ fear...just gritted their teeth...
Fred
