Ed Anderson
Posted: Fri Jul 06, 2012 3:36 am Post subject: Battery only time -Z-19RB clarification |
Personal experience with a Odyssey PC 680 (one). Apparently hit an
electrical switch with my foot at refueling stop which removed the
alternator feed from my battery. I had two EFI fuel pumps running plus
electronic fuel injectors (4) and dual ignition and normal comm/nav gear on.
About 40 minutes after take off, engine started to miss which condition then
gradually deteriorated - I misdiagnosed the problem as being related to fuel
feed and failed to notice decreasing battery voltage (have one volt meter
that I switch between battery and alternator feeds). The voltmeter was set
to monitor the alternator (which was working fine by the way) and the
voltage remained at 13.8 volts until engine stoppage at 45 minutes and 5
miles out from Selma Al.
Deadsticked it to a safe airport landing and later discovered battery
voltage was down to six volts - switch in wrong position precluded
alternator power from feeding the battery - yes, design flaw! - since
corrected. Initially, during design phase, I was concerned about a "run
away alternator" causing the battery (inside the cockpit) to possibly
boil/explode. Have a auto alternator so pulling the field coil CB after it
has bootstrapped does no good - alternator keeps on producing - so I decided
a switch to isolate alternator and battery might be smart. In hindsight,
the odds of that condition happened were much less than the switch designed
to prevent being accidently mis-positioned {:<(.
But, my point is that my PC680 did a good job for longer than I would have
expected. So I feel I have a reasonably reliable 30 minutes after
encountering such a problem to making it to the airport for a safe landing.
Had the battery been fully charged - it never charged after engine start and
that drain due to the switch position - I think 5-10 minutes more might have
been achieved. However, in hind sight that would have just placed me
further from the airport. Clearly useful time depends on battery condition
and load.
The key, of course, is early indication/recognition of the problem. No my
yellow low voltage light never came on - because the alternator never
stopped producing voltage.
FWIW
Ed
Edward L. Anderson
Anderson Electronic Enterprises LLC
305 Reefton Road
Weddington, NC 28104
http://www.andersonee.com
http://www.eicommander.com
Sent: Thursday, July 05, 2012 8:11 PM
To: <aeroelectric-list(at)matronics.com>
Subject: RE: Z-19RB clarification
At 09:52 PM 7/4/2012, you wrote:
<afulmer(at)charter.net>
Roger,
I am using Z-19RB in my Subaru H6 powered RV7. My understanding as to why
the endurance bus alternate feed is from the Main Battery only is that the
engine bus and its battery are reserved for the running of the engine
alone
just as long as possible. I guess if you lose the main battery and thus
the
endurance bus then you can still fly the airplane to a safe landing site
as
long as the engine is running. Whereas, if you lose the engine
battery/bus
the endurance bus is not going to do you any good as you glide to a
landing.
I am sure Bob will chime in with a more elegant explanation.
During normal operations, BOTH batteries are on
line and behave as a single battery equal to their
combined capacity.
When the low volts warning light comes on, all you
have to finish the flight is what ever is carried
in the two batteries.
At that point in time you drop to the ENDURANCE MODE.
Run no piece of equipment that is not necessary for
a no-sweat return to earth.
Repeat after me: "I will KNOW what the capacity of
my batteries is at all times by which I will KNOW
what my endurance limits are in alternator-out
conditions." This usually calls for getting the
battery contactors out of the picture . . . turning
off both battery switches, running the engine from
the engine battery and minimum electro-whizzies on
the endurance bus. Once you have the airport in sight
and are cleared to land, you can turn the main battery
back on and use what ever is left to make a grander
entrance . . . but the idea is that you've kept
the engine's power source fire-walled off in a
separate energy bucket.
Now, if you want to add a second failure to this
scenario, then BOTH battery switches are placed to
ON and you begin moves to expedite landing while
watching bus voltage readings. When it gets down
to 10.5 volts, your on-board battery energy is
more than 95% used up. You need to be on short
final before that time.
Being able to switch the engine from one battery
to the other is a hedge against contactor failure
stacked on top of other failures . . . a statistical
tiny dot on the great horizon of possibilities for
one failure.
Checked by AVG - www.avg.com
_________________ Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com |
james(at)etravel.org Guest
Posted: Fri Jul 06, 2012 5:37 am Post subject: Battery only time -Z-19RB clarification |
Ed,
That's an interesting tale about the extra switch & the voltmeter. Glad you got back okay to tell it.
James
On 6 July 2012 12:35, Ed Anderson <eanderson(at)carolina.rr.com (eanderson(at)carolina.rr.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Ed Anderson" <eanderson(at)carolina.rr.com (eanderson(at)carolina.rr.com)>
Personal experience with a Odyssey PC 680 (one). Apparently hit an electrical switch with my foot at refueling stop which removed the alternator feed from my battery. I had two EFI fuel pumps running plus electronic fuel injectors (4) and dual ignition and normal comm/nav gear on.
About 40 minutes after take off, engine started to miss which condition then gradually deteriorated - I misdiagnosed the problem as being related to fuel feed and failed to notice decreasing battery voltage (have one volt meter that I switch between battery and alternator feeds). The voltmeter was set to monitor the alternator (which was working fine by the way) and the voltage remained at 13.8 volts until engine stoppage at 45 minutes and 5 miles out from Selma Al.
Deadsticked it to a safe airport landing and later discovered battery voltage was down to six volts - switch in wrong position precluded alternator power from feeding the battery - yes, design flaw! - since corrected. Initially, during design phase, I was concerned about a "run away alternator" causing the battery (inside the cockpit) to possibly boil/explode. Have a auto alternator so pulling the field coil CB after it has bootstrapped does no good - alternator keeps on producing - so I decided a switch to isolate alternator and battery might be smart. In hindsight, the odds of that condition happened were much less than the switch designed to prevent being accidently mis-positioned {:<(.
But, my point is that my PC680 did a good job for longer than I would have expected. So I feel I have a reasonably reliable 30 minutes after encountering such a problem to making it to the airport for a safe landing. Had the battery been fully charged - it never charged after engine start and that drain due to the switch position - I think 5-10 minutes more might have been achieved. However, in hind sight that would have just placed me further from the airport. Clearly useful time depends on battery condition and load.
The key, of course, is early indication/recognition of the problem. No my yellow low voltage light never came on - because the alternator never stopped producing voltage.
FWIW
Ed
Edward L. Anderson
305 Reefton Road
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
To: <aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)>
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
--> AeroElectric-List message posted by: "Allen Fulmer" <afulmer(at)charter.net (afulmer(at)charter.net)>
Roger,
engine bus and its battery are reserved for the running of the engine alone
just as long as possible. I guess if you lose the main battery and thus the
endurance bus then you can still fly the airplane to a safe landing site as
long as the engine is running. Whereas, if you lose the engine battery/bus
the endurance bus is not going to do you any good as you glide to a landing.
combined capacity.
one failure.
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
e -
Posted: Fri Jul 06, 2012 5:46 am Post subject: Battery only time -Z-19RB clarification |
FWIW
Ed
I'm pleased that your experience had a happy ending.
An obstacle to be overcome in the OBAM aviation
community is information and collaboration. When you
work for a 60+ year old company of 6,000 plus employees
and 800 engineers, there is a wealth of history to
call on for things that work well and things that don't
work well.
We are acutely aware of this shortcoming in OBAM aviation
which tends to drive low risk worries into actions that create
more risk than they fix. EAA was the first real big
leap into a collaboration for sharing information.
In years since, the Internet has offered still greater
coverage with convenience.
But the tendencies to over-think a problem are still
there. The most powerful prophylactic against the
unintended consequences that raise risk is collaboration.
Thank you for sharing your experience with the List.
Ed Anderson
Posted: Fri Jul 06, 2012 6:45 am Post subject: Battery only time -Z-19RB clarification |
I certainly agree, Bob. A clear case of a where my design focused on a very
low probability occurrence (boiling battery) ending up almost assuring that
at some point that switch would get in the incorrect position and cause a
problem.
In fact, has anybody on the list EVER experienced or have first hand
knowledge of someone who had a battery boil/overheat due to run away (over
voltage) alternator??
Ed
Sent: Friday, July 06, 2012 9:45 AM
Subject: Re: Battery only time -Z-19RB clarification
>FWIW
>Ed
work well.
Matthews, NC
Ed Anderson
Posted: Fri Jul 06, 2012 7:08 am Post subject: Battery only time -Z-19RB clarification |
Thanks, James - always willing to share my experience (no matter how embarrassing) in view it could save someone else from the same experience.
One thing I didn't mention was when about 5 miles out with prop stopped, I was thinking at least everything is working but the engine, the panel lights were still on and the radio, so got on the radio to let traffic know I was coming in without engine power. I made one call when there was an ominous "clack" ( would have never hear it with the engine running) - all panel lights go dead as well as the radio - now it was really lonesome up there.
I later realized that when the battery voltage dropped below sustaining level - the master relay contactor (powered by the battery) released and even the alternator power that had been feeding the panel through that contactor went south. (another design flaw!).
But, with no further distractions, I could now concentrate on making sure I didn't screw up this deadstick landing. To show you how distracted I had been, it wasn't until I hit pattern altitude on down wind that the sudden realization hit - that I there was not going to be any maintaining altitude to make that nice base turn at my opinion someplace on downwind.
I Immediately initiated the base turn, then found myself wanting to tighten up the turn (was a little close in on downwind - guess you could say I was "hugging" the runway - the comfort factor{:>)) Then a little voice warning about the "Coffin corner turn on base" made me look at my airspeed in the turn and it was down to 80 mph and rate of descent up to 1000 fpm. I decided I would rather land in the grass (overshooting my turn) than dig a hole in the concrete), so I loosened up my turn and lowered the nose to pick up airspeed (hard to do with the ground staring me in the face). But, luck or whatever, it all came together in the last 100 ft or so. Flared to a perfect landing on the runway, rolled to the end of the runway and made the turn off to the taxiway coming to a welcomed stop.
So I think its just as important to know when to stop worrying the technical problem and start worrying about your butt and concentrate on the flying{:>)
Ed
Sent: Friday, July 06, 2012 9:36 AM
Ed,
James
| Quote: | --> AeroElectric-List message posted by: "Ed Anderson" <eanderson(at)carolina.rr.com (eanderson(at)carolina.rr.com)>
FWIW
Ed
Edward L. Anderson
305 Reefton Road
Roger,
combined capacity.
one failure.
MS -
e -
Version: 2012.0.2195 / Virus Database: 2437/5114 - Release Date: 07/06/12 [quote][b]
Matthews, NC
Posted: Fri Jul 06, 2012 6:31 pm Post subject: Battery only time -Z-19RB clarification |
So I think its just as important to know when to stop worrying the technical problem and start worrying about your butt and concentrate on the flying{:>) | What changes have you made to architecture, development of a Plan-B, and for a preventative maintenance program to make sure your battery(ies) are of known quantity?
Bob . . . [quote][b]
