		| Author | Message |
		| william(at)wbliss.co.uk Guest
				|  Posted: Sun Jul 08, 2012 2:18 pm    Post subject: fuel smell |   |
				| I had an enjoyable flight in a Europa today. The main drawback was that
the fuel smell was there - and became very strong and off putting when I
 was trying sideslips. Tank was about half full. I do not think it can be
 due to fumes permeating through the tank wall. When I had a look up
 inside the the under - fuselage panel, I could not see any evidence of
 fuel leakage. The tank did not look wrinkled or warped. Could there be a
 vent leaking somewhere? Does an aluminium tank have the same problem?
 What I really need is an idea of cost and time to fix it.
 I suspect this has been discussed before
 William Bliss
		| Back to top |  |
		| ward.t(at)xtra.co.nz Guest
				|  Posted: Sun Jul 08, 2012 2:39 pm    Post subject: fuel smell |   |
				| William,
Look at the seal near the fuel intake cap. Make sure it has been sealed completely between the plastic cobra and fuel cap body.
 Otherwise the rubber pipe maybe allowing fuel to permeate through creating the smell?
 Cheers,
 Tim Ward
 12 Waiwetu Street
 Fendalton,
 Christchurch,  8052
 New Zealand.
 Ph 64 3 3515166
 Mob 0210640221
 On 9/07/2012, at 10:18 AM, William Bliss <william(at)wbliss.co.uk> wrote:
  	  | Quote: |  	  |
 I had an enjoyable flight in a Europa today. The main drawback was that the fuel smell was there - and became very strong and off putting when I was trying sideslips. Tank was about half full. I do not think it can be due to fumes permeating through the tank wall. When I had a look up inside the the under - fuselage panel, I could not see any evidence of fuel leakage. The tank did not look wrinkled or warped. Could there be a vent leaking somewhere? Does an aluminium tank have the same problem? What I really need is an idea of cost and time to fix it.
 William Bliss
		| Back to top |  |
		| rehn(at)rockisland.com Guest
				|  Posted: Sun Jul 08, 2012 3:52 pm    Post subject: fuel smell |   |
				| Someone suggested checking the connection at top of cobra and fuel cap.
I found I had a slight leak there that would randomly seep at fill time from the fuel sloshing around and finding it's way in at that point, drove me crazy could smell it but couldn't see it. I resealed and bought one of those flexible fuel extenders that fits over the end of your portable fuel tank nozzle. It's about 12 inches long and allows me to push it down the cobra a few more inches so the fuel doesn't slosh around the fitting when fueling up. I bought mine in the auto section at Walmart I think. But you should find them anywhere they sell portable fuel tanks.
 Some day I will get in and make a better seal, but for now, no leak and no smell.
 Sent from my iPad
 On Jul 8, 2012, at 3:18 PM, William Bliss <william(at)wbliss.co.uk> wrote:
  	  | Quote: |  	  |
 William Bliss
		| Back to top |  |
		| houlihan(at)blueyonder.co Guest
				|  Posted: Mon Jul 09, 2012 12:41 am    Post subject: fuel smell |   |
				| Hi Tim.
 He says it is a classic so unless it is modified to XS standard it would not have a "cobra" just a long permeable rubber hose.
 The comments about side slip makes me wonder if it is an exhaust issue rather than a smell from the hose.
 Tim H
 On 8 July 2012 23:40, Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)> wrote:
 [quote] --> Europa-List message posted by: Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)>
 William,
 Cheers,
 Tim Ward
 12 Waiwetu Street
 Fendalton,
 Christchurch,  8052
 New Zealand.
 Ph 64 3 3515166
 Mob 0210640221
 On 9/07/2012, at 10:18 AM, William Bliss <william(at)wbliss.co.uk (william(at)wbliss.co.uk)> wrote:
 > --> Europa-List message posted by: William Bliss <william(at)wbliss.co.uk (william(at)wbliss.co.uk)>
 > William Bliss
		| Back to top |  |
