Contactor redux
PostPosted: Fri Jul 13, 2012 11:32 am    Post subject: Contactor redux Reply with quote
At 02:15 PM 7/13/2012, you wrote:
<nuckolls.bob(at)aeroelectric.com>
At 02:03 PM 7/13/2012, you wrote:
Howdy,
I just recieved from B&C a starter contactor S701-1 which, unlike all
the others I've seen, has plastic covers on the mounting tabs. Where
is this guy going to get a coil ground connection? Is the intention
to wire through the switch to ground?
http://www.bandc.biz/pdfs/S701-1_Wiring.pdf
Pax,
Ed,
The S701-1 is a continuous duty battery master
contactor and not intended for service as a
starter contactor. This is why it is shipped
configured as a Battery contactor which gets a
ground through the battery master switch.
If you wish to use this contactor to control power
to your starter, you remove the jumper wire installed
and run your starter push button to the left, small
terminal. You add a longer jumper from the right,
small terminal to ground.
AHA! I see the point of confusion. The B&C wiring
diagram cited calls for running a fat wire to
the "starter contactor" which means the HOT side
of the starter contactor which shares a connection
to the ship's main bus. This isn't intended to
imply that this contactor is used for starter
control.
The image might better read, "To main bus via hot
side of starter contactor"
If you're looking for a starter contactor . . . I
suggest you consider the S702-1 or equivalent.
http://tinyurl.com/6p8raot
Checked by AVG - www.avg.com
raymondj(at)frontiernet.n
PostPosted: Fri Jul 13, 2012 12:26 pm    Post subject: Contactor redux Reply with quote
I noticed that crimp-on terminals were used on the solid leads on the
diode. It was my understanding that using crimp-ons on solid wire was
not recommended. Am I misinformed....again? Smile
Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
Howdy,
the others I've seen, has plastic covers on the mounting tabs. Where is
this guy going to get a coil ground connection? Is the intention to wire
Pax,
Ed,
-------------------------------snip--------------------------------
PostPosted: Fri Jul 13, 2012 3:47 pm    Post subject: Contactor redux Reply with quote
At 03:22 PM 7/13/2012, you wrote:
--> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net>
I noticed that crimp-on terminals were used on the solid leads on the diode. It was my understanding that using crimp-ons on solid wire was not recommended. Am I misinformed....again? Smile
Is that something I wrote? If it was, I cannot recall
a context where that would be true. Here's a photomicrograph
I just shot for 22AWG solid wire (diode lead) crimped into a
red PIDG using an el-cheapo crimp tool.
[img]cid:7.1.0.9.0.20120713183738.01e17628(at)aeroelectric.com.0[/img]
I couldn't find my polishing disk so the smoothed end is
rather rough. Normally you'd be able to see the ring of
tin plating on the wire at the interface between wire
and terminal barrel. Nonetheless, this photo confirms that
the two metals to be joined have been upset with sufficient
force to make them essentially one with no voids.
 Filesize:  159.56 KB
 Viewed:  2990 Time(s)
PostPosted: Fri Jul 13, 2012 4:21 pm    Post subject: Contactor redux Reply with quote
I thought I saw it one of the electronics catalogs. I'll do a little
looking around and see if I can find where I saw it. Thanks again for
the info.
Raymond Julian
Kettle River, MN.
> Bob,
Emacs!
