				 Posted: Thu Jul 12, 2012 6:26 pm    Post subject: Lyc cylinder service shop? |
				Can anyone recommend a cylinder         shop that will basically do a valve job on a cylinder? I've got         cylinders that are basically in great shape with good (mid 70's)         compression, but I suspect worn valve guides. I've already got         them off the motor, so I'd like to just get the top topped, if         you know what I mean.
          A shop in the southeast would be a plus (less shipping         time/expense).
          Charlie
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Kellym
				 Posted: Thu Jul 12, 2012 6:28 pm    Post subject: Lyc cylinder service shop? |
				Zepyr in Zephyrhills FL is one. There also is Tri something or other in NC.
 On 7/12/2012 7:25 PM, Charlie England wrote:
  	  | Quote: | 	 		   Can anyone recommend a cylinder shop that will basically do a valve
  Charlie
 Checked by AVG - www.avg.com
KCHD |
				 Posted: Thu Jul 12, 2012 6:36 pm    Post subject: Lyc cylinder service shop? |
				Try Zephyr engines in Zephyr Hills, FL.
  Good people and a good reputation.
  [quote]   ---
		Larry Bowen
				 Posted: Thu Jul 12, 2012 6:40 pm    Post subject: Lyc cylinder service shop? |
				I think the shop at BUY could do it.
 Larry Bowen
  Larry(at)BowenAero.com
  ceengland(at)bellsouth.net (ceengland(at)bellsouth.net)> wrote:[quote]                     Can anyone recommend a cylinder         shop that will basically do a valve job on a cylinder? I've got         cylinders that are basically in great shape with good (mid 70's)         compression, but I suspect worn valve guides. I've already got         them off the motor, so I'd like to just get the top topped, if         you know what I mean.
          Charlie
 t="_blank">http://www.matronics.com/Navigator?RV-List
 tp://forums.matronics.com
  _________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
				 Posted: Fri Jul 13, 2012 1:55 pm    Post subject: Lyc cylinder service shop? |
				OK, that's 2 for Zephyr & one for the one at BUY. I'll try to     check with both.
      Not any in Memphis or New Orleans are there? That's close enough to     create an excuse to drive/play.   (From Jackson MS)
      How about an online copy of the Lyc parts catalog for the old narrow     deck O-320's? I've found 2 or 3 versions for the wide deck 320's,     but none so far for my O-320 B2A.
      Thanks again,
      Charlie
      'Save the date': 1st Saturday in November is the Slobovia Pumpkin     Drop here at MS71.
      On 07/12/2012 09:40 PM, Larry Bowen wrote:     [quote]
 Larry Bowen
          Larry(at)BowenAero.com (Larry(at)BowenAero.com)
          ceengland(at)bellsouth.net (ceengland(at)bellsouth.net)>         wrote:          	  | Quote: | 	 		              Can anyone recommend a cylinder shop that                 will basically do a valve job on a cylinder? I've got                 cylinders that are basically in great shape with good                 (mid 70's) compression, but I suspect worn valve guides.                 I've already got them off the motor, so I'd like to just                 get the top topped, if you know what I mean.
                  Charlie
