Posted: Tue Jul 17, 2012 9:32 am Post subject: Bearing material |
Hello,
Could someone tell me the material that the control stick bearing blocks are made from. There is a similar piece of material on the mono wheel for the gear retract lever.
I thought this called Tufnol, but when I searched McMaster Carr I could not find it.
Thanks and regards, Paul
pete(at)lawless.info Guest
Posted: Tue Jul 17, 2012 10:00 am Post subject: Bearing material |
Hi Paul
It is called Tufnol. Plenty of suppliers via Google UK & US.
Pete
jan_de_jong(at)casema.nl Guest
Posted: Tue Jul 17, 2012 10:12 am Post subject: Bearing material |
Paul,
McMaster calls it "phenolic" and "Garolite".
Don't know the specific quality the bearings are made of.
Jan
On 7/17/2012 7:58 PM, Pete Lawless wrote:
[quote] 14 Hantone Hill
Hi Paul
Pete
rlborger(at)mac.com Guest
Posted: Tue Jul 17, 2012 10:26 am Post subject: Bearing material |
Paul,
The US trade name is Micarta.
On Jul 17, 2012, at 12:32, Paul McAllister <paul.the.aviator(at)gmail.com (paul.the.aviator(at)gmail.com)> wrote:
| Quote: | Hello,
Rocketman
Posted: Tue Jul 17, 2012 11:22 am Post subject: Bearing material |
Paul, it's a phenolic resin...
Jeff
On 7/17/2012 12:32 PM, Paul McAllister wrote:
| Quote: | Hello,
not find it.
Checked by AVG - www.avg.com <http://www.avg.com>
A266
Posted: Tue Jul 17, 2012 1:14 pm Post subject: Bearing material |
Paul,Look for "phenolic sheet". Available from a lot of us sources dealing with plastics. Also Aircraft Spruce and McMaster Carr sells it in smaller quantities. Sent via BlackBerry by AT&T
From: Paul McAllister <paul.the.aviator(at)gmail.com>
Sender: owner-europa-list-server(at)matronics.com
Date: Tue, 17 Jul 2012 12:32:03 -0500
To: <europa-list(at)matronics.com>
ReplyTo: europa-list(at)matronics.com
Subject: Europa-List: Bearing material
Hello,
Could someone tell me the material that the contr= ol stick bearing blocks are made from. There is a similar piece of material= on the mono wheel for the gear retract lever. =A0
I thought this called Tufnol, but when I searched McMaster Carr I could not= find it.
Posted: Tue Jul 17, 2012 10:16 pm Post subject: Bearing material |
Paul
it is Tufnol, laminated with linen cloth and phenolic resin. There are similar boards using paper instead of cloth. Not as good.
Graham
Sent: Tuesday, 17 July 2012, 18:32
Subject: Bearing material
Hello,
[quote]http://www.matronics.com/Navigator?Europa-Listofollow" target="_blank" href="http://www.matronics.com/contribution">h
