oil Temps
airman(at)appledumplings.
PostPosted: Fri Jun 02, 2006 8:51 am    Post subject: oil Temps Reply with quote
What oil temp is normal in summer for the tiger? and what is the
highest it should run?
flyv35b(at)ashcreekwirele
PostPosted: Fri Jun 02, 2006 1:19 pm    Post subject: oil Temps Reply with quote
Probably between 180-200F or maybe a bit hotter during an extended climb is
pretty typical. If it gets to 220 F I would do something to reduce it or
keep it from getting any higher. But 245 F is the max redline oil temp.
Cliff A&P/IA
GrummanDude
PostPosted: Fri Jun 02, 2006 2:08 pm    Post subject: oil Temps Reply with quote
In a message dated 6/2/06 9:53:20 AM, airman(at)appledumplings.com writes:
What oil temp is normal in summer for the tiger?=A0 and what is the=A0
=20
I just installed a JPI 700 in a Cheetah with the small oil cooler. At 80=20
OAT, the oil temp was around 220. It was a new engine so I suspect it will=
get=20
better.
On my Tiger, I normally see 190 for a max temp. =20
Anything in the over 180 and under 200 range (i.e., 180 < Oil Temp < 200 )=
=20
is acceptable. If the oil temp gets much higher, keep it rich, and, if=20
necessary, reduce power. =20
I strongly recommend the larger oil cooler for the Cheetah/Traveler. =20
Gary
Gary
AuCountry Aviation
Home of Team Grumman
