				 Posted: Sun Jul 22, 2012 6:02 am    Post subject: Weight of HPL 3 blade warp drive prop for ref |
				Graeme, You want to adjust the fine limit to give you a
 max static of 5650 . Significantly less will lose you some
 power & more will put you at risk of over speeding if you
 slam the throttle open in a go around situation. The
 coarse stop will probably look after itself but you need
 to be able to get a positive rate of climb at MAUW and
 fully coarse. Adjusting the stops is not at all difficult.
 Woodcomp will give you instructions if you ask them, or if
 here are any problems I can probably find the instructions
 they gave me.
 Regards, David, G-XSDJ
 On Sun, 22 Jul 2012 01:40:57 -0700
   "graeme bird" <graeme(at)gdbmk.co.uk> wrote:
  Well I have fitted to Woodcomp 3000/3W and done a couple
 of short initial test flights. The LAA test schedule
 seems to imply that I might need to adjust the
 microswitch positions but the Woodcomp manual says this
 should only be done at the factory. Did anyone find it
 necessary to adjust them and if so did they do it
 themselves of get Kevin involved? I guess I am asking
 Carl and David.
  So far the take off seems much more rapid, but then it
 seemed to stop accelerating at just above 60kts and I
 have to go to climb and put the gear up. The top end
 doesnt seem that much faster but then I may not have been
 applying full power. Not sure whether to display pressure
 or HP on the controller.
  Graeme Bird
  G-UMPY
  Mono Classic/XS FWFD 912ULS/Warp drive FP
  Newby: 35 hours
  g(at)gdbmk.co.uk
  http://forums.matronics.com/viewtopic.php?p=378909#378909
 Un/Subscription,
 Forums!
 Admin.
