ELT antenna
rickofudall
PostPosted: Sun Jul 22, 2012 11:33 am    Post subject: ELT antenna Reply with quote
For some reason, God only knows why he did half the things he did to this airplane, the previous owner of an E-LSA cut the antenna for a 121.5 Ameri-King ELT down to 14.3" (measured from the base, he bent it, too). What's the rule on a TSO'd unit in an experimental plane? Can I just solder an extension on it to bring it back to the correct length or does it have to be as the manufacturer made it? I don't own it, but I have to sign off the annual.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
