Keith.Miller(at)esa.int Guest
Posted: Sun Jul 29, 2012 10:34 pm Post subject: IO-240B With the 15V 60A TCM alternator |
At 450hrs the drive coupling on my alternator has failed , maybe its just
coincidence with the experience of Tim last year where his failed at
around the same number of hours , I stripped it out yesterday and it is the
same elastomeric one piece assembly.
Question : Tim or anyone else , what was your opinion of the Drake
rebuild , how long did it take and any contact details.
Keith
|Keith.Miller(at)esa.int |
| To: |
|kis-list(at)matronics.com |
| Date: |
|04/03/2011 11:23 |
| Subject: |
|Re: IO-240B With the 15V 60A TCM alternator |
| Sent by: |
|owner-kis-list-server(at)matronics.com |
Hopefully mine will last a bit longer , but good to know that there are some
options
From: "helixaviation(at)googlemail.com" <helixaviation(at)btinternet.com>
To: kis-list(at)matronics.com
Date: 04/03/2011 11:11
Subject: Re: IO-240B With the 15V 60A TCM altinator
Sent by: owner-kis-list-server(at)matronics.com
Keith. My alternator drive coupling failed after about 50 hours. I put it
down to kickback on startup and had the mags retarded a little. The original
coupling was elastomeric and had failed in sheer. I managed to locate an
alternative style that was mechanical but has rubber inserts for shock
absorbtion. I got it second hand and from memory only cost about £100. John
Sent from my Android phone with K-9 Mail. Please excuse my brevity.
Keith.Miller(at)esa.int wrote:
want to hear , my IO240B is just coming up to 400hrs , but thanks for
sharing it with us anyway , at least the shock will be less when it
eventually happens to mine Keith From: "F. Tim Yoder"
<ftyoder(at)yoderbuilt.com> To: <kis-list(at)matronics.com> Date: 04/03/2011
04:09 Subject: IO-240B With the 15V 60A TCM altinator Sent by:
owner-kis-list-server(at)matronics.com FYI, I was fly a couple weeks ago and
lost The Alt. I determined that the Alt. was not producing power and
removed it. I am sure Cont. could have made that job harder if they tried.
I found the Alt. was ok but the Alt. Drive Coupling Assembly (P/N 635796)
was broken, the Lord rubber mount came loose from the ss shroud. Better if
the Alt was bad. The bad news is that Cont. wants $2077.00 for this part,
no, the engine is not included! The not so bad news is that Drake rebuilds
them and they can be had for $600.00 to $900.00, with a good core. I only
had a little over 400 hrs. on the engine. I had to remove a Slick Mag to
get the Alt. out, so I had the mag 500 hr service done. New points and
replaced a bad gear. So for only a $1000.00 + I now have lots of amps &
volts. Hope you have the "good" ones!
This message and any attachments are intended for the use of the addressee or addressees only. The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its content is not permitted. If you received this message in error, please notify the sender and delete it from your system. Emails can be altered and their integrity cannot be guaranteed by the sender.
Please consider the environment before printing this email.
ftyoder(at)yoderbuilt.com Guest
Posted: Mon Jul 30, 2012 5:00 am Post subject: IO-240B With the 15V 60A TCM alternator |
I have started to look into the possibilities of switching to the old style
mechanical coupling, But I wonder if there were any good reasons why TCM
switched to the Elastomeric type,Did they have in field failures, or was it
simply to protect a 600$ alternator with a 2000$ coupling .
also I am wondering why it failed ? My alternator is spinning freely so it
wasn't due to this,
|"F. Tim Yoder" <ftyoder(at)yoderbuilt.com> |
| To: |
|<kis-list(at)matronics.com> |
| Date: |
|30/07/2012 14:39 |
| Subject: |
| Sent by: |
Keith,
Sorry to hear about that. A local FBO had one in stock so I wasn't down
long. They just cost to damn much. If you price a new one you will be glad
to get a rebuilt one . You might check with a mechanic about the
possibility of converting to the old geared system. Maybe OC has an idea if
that is possible or affordable.
Good luck, Tim
Posted: Mon Jul 30, 2012 6:26 am Post subject: IO-240B With the 15V 60A TCM alternator |
My alternator was also good. One of the local mechanics also wondered why
went to the bonded coupling. His experience was few failures of the gear.
One of the gears is designed to fail before damaging the alternator, is the
way I understand it.
Posted: Mon Jul 30, 2012 6:45 am Post subject: IO-240B With the 15V 60A TCM alternator |
Just spoke with Drakes representative and he said the most common cause of
failure was too high a load on the alternator immediately after start up
since this is when the alternator is running slow, Or if a large load is
suddenly put on the alternator in flight . He said they get a few in for
refurbishment every week, particularly in the summer when owners are
switching on the airco before start up ( are they battery operated ? ) ,
Clearly this is not my problem ( particularly in the cold Europe this
summer we have had ) but this has got me thinking and maybe its the lithium
Ion battery I installed earlier this year , immediately after startup it
draws very large currents which drop almost immediately ( these batteries
go from zero to fully charged in 15 mins ). It may have nothing at all to
do with this.
Keith
| To: |
| Date: |
|30/07/2012 16:27 |
| Subject: |
| Sent by: |
