millner(at)me.com Guest
Posted: Wed Jul 25, 2012 7:59 pm Post subject: fueling-created static discharge prevention |
On 7/10/2012 11:37 AM, bob noffs wrote:
| Quote: | lately i have been filling my plane out of 5 gal. plastic cans and i
am finding it not too time consuming. the biggest reason is higher
octane mogas than i can get at the airport.
anyway.............i need some advice on grounding.i have a 12 volt
pump mounted and it is powered by a battery 20 feet away. i have a
handheld switch . i set the plastic can on the table and fuel is
transferred thru vinyl tubing. at the airplane end is a metal filter.
pumps a gallon a minute. i plan to set up a ground to the exhaust pipe
[all tanks are grounded to the engine] but i do not know how to
ground the pump or hoses. any advice would be appreciated.
Hi Bob,
Technically, it's BONDING you're interested in... grounding isn't much
important unless you've experiencing lightening...
You need some metal screen at the 'can', a conductive hose (run a copper
wire through it that's the best you can do) and a connection at the tank
inlet on the airplane. All those nee to be bonded together electrically.
Paul
Please note my new email address!
millner(at)me.com
bobnoffs
Joined: 04 Jul 2012 Posts: 132 Location: northern wi.
Posted: Thu Jul 26, 2012 2:38 am Post subject: fueling-created static discharge prevention |
thanks paul.
bob noffs
On Wed, Jul 25, 2012 at 10:55 PM, Paul Millner <millner(at)me.com (millner(at)me.com)> wrote:
[quote]--> AeroElectric-List message posted by: Paul Millner <millner(at)me.com (millner(at)me.com)>
| Quote: | lately i have been filling my plane out of 5 gal. plastic cans and i am finding it not too time consuming. the biggest reason is higher octane mogas than i can get at the airport.
anyway.............i need some advice on grounding.i have a 12 volt pump mounted and it is powered by a battery 20 feet away. i have a handheld switch . i set the plastic can on the table and fuel is transferred thru vinyl tubing. at the airplane end is a metal filter. pumps a gallon a minute. i plan to set up a ground to the exhaust pipe [all tanks are grounded to the engine] but i do not know how to ground the pump or hoses. any advice would be appreciated.
Hi Bob,
Technically, it's BONDING you're interested in... grounding isn't much important unless you've experiencing lightening...
You need some metal screen at the 'can', a conductive hose (run a copper wire through it that's the best you can do) and a connection at the tank inlet on the airplane. All those nee to be bonded together electrically.
Paul
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
rvhad(at)yahoo.com Guest
Posted: Thu Jul 26, 2012 3:21 pm Post subject: fueling-created static discharge prevention |
i have a similar issue and my idea is to use a cable just like the AVGAS pump...grounded to the bolts that hold up the hanger
[quote] From: bob noffs <icubob(at)gmail.com>
To: aeroelectric-list(at)matronics.com t
Sent: Thursday, July 26, 2012 3:36 AM
Subject: Re: AeroElectric-List: fueling-created static discharge prevention
thanks paul.
bob noffs
| Quote: | --> AeroElectric-List message posted by: Paul Millner <millner(at)me.com (millner(at)me.com)>
Hi Bob,
Paul
le, List Admin.
http://www.matronics.com/Nav========================
" target="_blank" href="http://forums.matronics.com/">http://forums.mat===
