Posted: Mon Jul 30, 2012 7:59 am Post subject: fuel valve |
I think you did not wait long enough....and the purge valve is right up there next to the injectors for an immediate cut-off. Residual fuel could still be pressurised by the mechanical pump and keep the engine running for a couple of minutes....mine ran for a while with the selector in the off position....while I was still creating my startup checklists...
bifft(at)xmission.com Guest
Posted: Mon Jul 30, 2012 8:07 am Post subject: fuel valve |
On Mon, 30 Jul 2012, thomas sargent wrote:
| Quote: | In doing my annual inspection, when I was running the engine to warm up the
oil for an oil change, I tried to stop the engine by turning the fuel
selector valve to OFF. It continued running without slowing down for what
seemed like a long time (probably 1/2 to 1 minute) until I got tired of
waiting and turned off the purge valve (AFP fuel injection) which stopped
it immediately. The fuel flow gauge showed a steady 1.4 - 1.5 gph.
Did I just not wait long enough or is the fuel valve worn out? It's the
valve that Van supplied with the kit and otherwise shows no problems,
doesn't feel worn, etc.
The engine can run for quite a while on the fuel in the lines and the
gasocolator, especially at idle. I once meant to switch tanks and
switched the fuel off in flight, it took about 30 seconds before the
engine stopped. Did start right back up again when I switched the fuel
back on.
Brian Huffaker, DSWL (bifft(at)xmission.com)
RV-8A 80091 Planning panel
1/4 Starduster II N23UT down for engine overhaul
