Unapproved ELT antenna?
dlj04(at)josephson.com
PostPosted: Tue Jul 24, 2012 7:16 am    Post subject: Unapproved ELT antenna? Reply with quote
I wrote earlier
> The TSO (required to meet "approved" under FAR 91.207) generally includes
> the antenna supplied by the ELT mfr, so any modification would void the
> TSO. You'd have to check with Ameri-King. Bending the antenna is probably
> not a problem. It would not be a good idea to solder on an extension,
> mainly because many ELT antennas are physically shorter than quarter-wave
> due to the presence of loading coils, and you too would be modifying TSO'd
> equipment without approval. As the inspector, are you equipped to measure
> the radiated output in accordance with 91.207 (d)(4)?
Sorry, there should have been more detail. The point is that the FAR's
don't specify how to measure radiated output. Maybe it's in the
manufacturer's instructions, maybe not, in which case you're on your
own... different shops use different methods like using a portable radio
with no antenna or a remote receiver to see whether there is "sufficient
signal radiated from its antenna."
But check with Ameri-King, the shortened antenna may be factory length.
David
Kellym
PostPosted: Tue Jul 24, 2012 8:34 am    Post subject: Unapproved ELT antenna? Reply with quote
The requirements are in the TSO. The FARs require compliance with the
TSO. TSO approval is on the transmitter with antenna, which prevents
substitution with anything but identical antenna or one the manufacturer
has determined to perform identically.
radio with no antenna or a remote receiver to see whether there is
"sufficient signal radiated from its antenna."
David
Checked by AVG - www.avg.com
Kelly McMullen
KCHD
rickofudall
PostPosted: Tue Jul 24, 2012 1:22 pm    Post subject: Unapproved ELT antenna? Reply with quote
David, The antenna has definitely been hacked off. I have an identical Ameri-King ELT on my personal airplane and it is about 7 to 8 inches longer and has a ball end, no saw marks of ragged shrink tubing.I called the Wichita FSDO and got the answer. I can replace the antenna for the owner with an unaltered correct one, or I can get a ferry permit to fly it home to him and he can deal with it.
On the sufficient signal strength, the rule is basically there to require a check to see that the antenna is indeed radiating, i.e. connected properly to the radio. Get your hand held, tune to 121.5, activate the ELT, see that you get a signal on the hand held, and your done.
The inspector was kind enough to suggest a local shop that might have an antenna, Bevan Rabell, and the good folks there are trying to help.
Thanks Guys,
Rick Girard
On Tue, Jul 24, 2012 at 11:33 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
The requirements are in the TSO. The FARs require compliance with the TSO. TSO approval is on the transmitter with antenna, which prevents substitution with anything but identical antenna or one the manufacturer has determined to perform identically.
Sorry, there should have been more detail. The point is that the FAR's don't specify how to measure radiated output. Maybe it's in the manufacturer's instructions, maybe not, in which case you're on your own... different shops use different methods like using a portable radio with no antenna or a remote receiver to see whether there is "sufficient signal radiated from its antenna."
David
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
  - Groucho Marx
stuart(at)stuarthutchison
PostPosted: Wed Jul 25, 2012 1:40 am    Post subject: Unapproved ELT antenna? Reply with quote
Hi Rick,
I appreciate that 121.5 radiation is a measure of success, but not sure if you guys are talking about a 406 beacon.
You're best not to transmit live without approval .. otherwise, in no time at all (one 406 data burst) you will have triggered a DISTRESS phase at the RCC.
Kind regards, Stu<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Girard
Sent: Wednesday, July 25, 2012 7:21 AM
Subject: Re: Re: Unapproved ELT antenna?
David, The antenna has definitely been hacked off. I have an identical Ameri-King ELT on my personal airplane and it is about 7 to 8 inches longer and has a ball end, no saw marks of ragged shrink tubing. I called the Wichita FSDO and got the answer. I can replace the antenna for the owner with an unaltered correct one, or I can get a ferry permit to fly it home to him and he can deal with it.
Thanks Guys,
Rick Girard
David
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
bakerocb
PostPosted: Wed Jul 25, 2012 3:35 am    Post subject: Unapproved ELT antenna? Reply with quote
7/25/2012
Hello Rick, You wrote: “....or I can get a ferry permit to fly it home to
him and he can deal with it.”
Either one of two provisions of the FARs already give permission to fly that
airplane to the owner’s home field without the need for the paperwork of a
ferry permit. See here:
“91.207 Emergency locator transmitters.
(e) Notwithstanding paragraph (a) of this section, a person may—
(2) Ferry an airplane with an inoperative emergency locator transmitter from
a place where repairs or replacements cannot be made to a place where they
can be made."
or 91.207 (f)
"(10) An aircraft during any period for which the transmitter has been
temporarily removed for inspection, repair, modification, or replacement,
subject to the following:
(i) No person may operate the aircraft unless the aircraft records contain
an entry which includes the date of initial removal, the make, model, serial
number, and reason for removing the transmitter, and a placard located in
view of the pilot to show “ELT not installed.”
(ii) No person may operate the aircraft more than 90 days after the ELT is
initially removed from the aircraft;..."
'O C' Baker says "The best investment you can make is the effort to gather
and understand information."
Time: 02:22:49 PM PST US
Thanks Guys,
Rick Girard
rickofudall
PostPosted: Wed Jul 25, 2012 6:16 am    Post subject: Unapproved ELT antenna? Reply with quote
Stu, The following are excerpts from AIM section 6-2-5, Emergency Locator Transmitter (ELT), dealing with testing, false alarms, and reporting.
Testing
1. ELTs should be tested in accordance with the manufacturer's instructions. This should be done, preferably, in a shielded or screened room or specially designed test container to prevent the broadcast of signals, which could trigger a false alert.
2. When this cannot be done, aircraft operational testing is authorized as follows:
(a)    Analog 121.5/243 MHz ELTs should only be tested during the first five minutes after any hour. If operational tests must be made outside of this period, they should be coordinated with the nearest FAA Control Tower or Flight Ser-vice Station. Tests should be no longer than three audible weeps. If the antenna is removable, a dummy load should be substituted during test procedures.
(b)   Digital 406 MHz ELTs should only be tested in accordance with the unit's manufacturer's instructions.
(c)    Airborne tests are not authorized.
Rick
On Wed, Jul 25, 2012 at 4:39 AM, Stuart Hutchison <stuart(at)stuarthutchison.com.au (stuart(at)stuarthutchison.com.au)> wrote:
Hi Rick,
You're best not to transmit live without approval ... otherwise, in no time at all (one 406 data burst) you will have triggered a DISTRESS phase at the RCC.
Kind regards, Stu
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Richard Girard
Thanks Guys,
Rick Girard
David
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
klehman(at)albedo.net
PostPosted: Mon Jul 30, 2012 5:29 am    Post subject: Unapproved ELT antenna? Reply with quote
Exactly but there still seems to be misunderstanding...
When I follow the manufacturer's instructions and do the 3 month self
test, I was surprised to learn that my ACK E-04 unit immediately
transmits a short live 406 test burst. I know this because I then get an
email from the Canadian Search and Rescue center confirming receipt of
my "test signal". Unlike other pilots I've spoken to, I will continue to
follow the manufacturer instructions. It would seem that RCC has no
problem recognizing these as "test bursts" and there is no need for any
coordination with any authority when doing the self test. They obviously
know whose ELT it is. The GPS position does not go out on the test burst
of this unit because the self test is supposed to be done WITHOUT
aircraft power or GPS info being fed to the unit.
On my unit the self test means pressing the black "test/reset" button
NOT the red Emergency button. But the labelling is applied by the
installer and can be reversed. In fact the rev 1.6 installation manual
actually has the photo on Page 1 reversed. However the text says
"Caution: The “ON“ position marking on the placard must be aligned with
the red switch, the “TEST/RESET” marking must be over the black switch
(Fig. 5)". Perhaps some are installed backwards and that has caused
some problems leading to folks now avoiding the self tests??
BTW ACK no longer recommends using the Ameriking RCPI (panel indicator)
with the ACK E-04. There is a wiring reversal required if you do attempt
to do that but mine did not function even with the reversed wiring
connector.
Ken
reporting.
Testing
as follows:
(a) _Analog 121.5/243 MHz ELTs should only be tested during the first
five minutes_ after any hour. If operational tests must be made outside
(b) _Digital 406 MHz ELTs should only be tested in accordance with the
unit's manufacturer's instructions._
Rick
<stuart(at)stuarthutchison.com.au <mailto:stuart(at)stuarthutchison.com.au>>
wrote:
__
Hi Rick,
Kind regards, Stu______
*From:* owner-aeroelectric-list-server(at)matronics.com
<mailto:owner-aeroelectric-list-server(at)matronics.com>
<mailto:owner-aeroelectric-list-server(at)matronics.com>] *On Behalf Of
*Richard Girard
*Sent:* Wednesday, July 25, 2012 7:21 AM
*To:* aeroelectric-list(at)matronics.com
<mailto:aeroelectric-list(at)matronics.com>
*Subject:* Re: Re: Unapproved ELT antenna?
tubing.
your done.
to help.
Thanks Guys,
Rick Girard
factory length.
David
