Riveting to a paintesd surface
recapen(at)earthlink.net
PostPosted: Tue Jul 31, 2012 8:21 am    Post subject: Riveting to a paintesd surface Reply with quote
I am getting ready to add a doubler plate for an antenna I will be installing on the underside of my fuselage.
It is already painted.
My initial thoughts were to rivet as though the paint was not there and paint the rivets after. Not concerned about electrical bonding of the ground plane as I will be taking care of that inside the fuselage.
Will the paint affect the compression strength of the rivets?
Thoughts please,
Ralph
bifft(at)xmission.com
PostPosted: Tue Jul 31, 2012 8:39 am    Post subject: Riveting to a paintesd surface Reply with quote
I doubt it would be significant. Don't most of us rivit primed parts?
Not much different between that and paint.
Brian Huffaker, DSWL (bifft(at)xmission.com)
RV-8A 80091 planning panel
1/4 Starduster II N23UT flying
carl.froehlich(at)verizon
PostPosted: Tue Jul 31, 2012 9:12 am    Post subject: Riveting to a paintesd surface Reply with quote
Or, don't rivet. You can use the antenna mounting hardware to hold the doubler plate in, and add an adhesive between the inside of the skin and the doubler plate.
WRT electrical bonding, remember the objective is to achieve an RF ground, not necessarily a DC ground. Doing as I suggest above will provide the RF ground.
Carl
On Jul 31, 2012, at 12:21 PM, "Ralph E. Capen" <recapen(at)earthlink.net> wrote:
Thoughts please,
Ralph
