arplnplt(at)gmail.com Guest
Posted: Sat Aug 04, 2012 7:31 pm Post subject: leaking brake calipers |
I flew into OSH and landed on runway 9 last Friday during the show. I had to taxi quite a distance on turf to get to the HBP area with the other 10's. As I got closer to the parking area, i noticed my brakes getting spongy.
I don't think I ride the brakes much at all but taxiing on the grass made me tap dance on them quite a bit. I few back to KUES that evening and found a leaking right caliper. Opened it up and found the o-ring pretty worn on one side, almost flat. The wall looked good with no sign of scoring or scratches. I replaced the o-ring but have not tested the brakes yet. I also found the left caliper leaking slightly as well. Have not inspected it yet. The plane has about 170 hours. Had no problems prior to this flight.
The question is, would heating up the brakes cause the o-rings to fail?
Dave Leikam
rv10pro(at)gmail.com Guest
Posted: Sat Aug 04, 2012 7:48 pm Post subject: leaking brake calipers |
Yes, and if your running H-5606 with Fiberglas pants you can support more activity than you did.
P.S. carry an extinguisher
David Leikam <arplnplt(at)gmail.com> wrote:
Dave Leikam
kdbelue(at)charter.net Guest
Posted: Sat Aug 04, 2012 8:08 pm Post subject: leaking brake calipers |
Yes, I had the same problem. Changed the oring to viton - I always use the mil-h-83282 fluid. I'm sure I would've had a fire with 5606 fluid.....
On Aug 4, 2012, at 10:30 PM, David Leikam <arplnplt(at)gmail.com> wrote:
Dave Leikam
Kellym
Posted: Sat Aug 04, 2012 8:12 pm Post subject: leaking brake calipers |
Do you happen to have the viton part number for the Cleveland calipers?
On 8/4/2012 9:07 PM, Kevin Belue wrote:
> Dave Leikam
KCHD |
Posted: Sat Aug 04, 2012 8:22 pm Post subject: leaking brake calipers |
Not right now, it's at the hangar. I can get it tomorrow if no one else replies....
On Aug 4, 2012, at 11:11 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
> Sent from my iPhone
>> Dave Leikam
Tim Olson
Posted: Sat Aug 04, 2012 8:44 pm Post subject: leaking brake calipers |
Dave, you definitely want the high-temp brake fluid (cheap
at Skygeek.com), and the viton o-rings. They'll hold up
much better. On my site, I have the viton part number on
one of my write-ups:
http://www.myrv10.com/N104CD/maintenance/20080503/index.html
Just search Viton on the page and you find:
The Viton o-rings are M83248/1-224 V-75
I bought some additional ones from McMaster Carr.
1201T856 MIL-Spec Viton(R) Fluoroelastomer O-Ring,
AS568A Dash Number 224, packs of 10
I also got these as spares...I think these were for the prop:
4198T265 MIL-Spec Buna-N O-Ring, A75 Durometer,
AS568A Dash Number 228, packs of 25
Good luck,
On 8/4/2012 11:11 PM, Kelly McMullen wrote:
| Quote: | >
> Sent from my iPhone
>> Dave Leikam
Posted: Sun Aug 05, 2012 5:03 am Post subject: leaking brake calipers |
Thanks! I'll get the viton seals and give them a try. I use Amsoil ATF fluid. https://www.amsoil.com/storefront/ATF.aspx?zo=1785021ww.amsoil.com/storefront/A
And I carry a Halon extinguisher. 170 hours and the pads look OK although I just ordered Rapco pads, rotors and desser tires.
Dave Leikam
On Aug 4, 2012, at 10:30 PM, David Leikam wrote:
Dave Leikam
Kellym
Posted: Sun Aug 05, 2012 7:22 am Post subject: leaking brake calipers |
Hmm,
While the Amsoil is a hydraulic fluid, I don't know that it tells you
anything about its suitability for aircraft brakes. Things like
compatibility with seals, flash point, viscosity vs temp range.
Given that the Royco 782 that is aircraft brake fluid, and is compatible
with all other aircraft brake fluids, is within $1 of the same price for
a quart, I question this diversion to non-aircraft fluid. When you leak
some and need to top off at an FBO, will you know how 5606 that they
have on hand will react with the Amsoil? TheMIL-PRF-83282D assures that
the Royco will be compatible, only losing some of its higher flash
point, if mixed.
I can't imagine why you would need rotors before you have a few thousand
hours on the plane.
Kelly
On 8/5/2012 6:02 AM, David Leikam wrote:
Dave Leikam
> Dave Leikam
KCHD |
Posted: Sun Aug 05, 2012 7:45 am Post subject: leaking brake calipers |
I ordered the rotors just to keep on the shelf as long as I was stocking up on pads and other parts. I was recommended to use the ATF a while ago, and after some research decided to use it. Higher flash point as well.
Again, look here - https://www.amsoil.com/storefront/ATF.aspx?zo=1785021ww.amsoil.com/storefront/A
Your point is well taken however.
Dave Leikam
On Aug 5, 2012, at 10:21 AM, Kelly McMullen wrote:
Hmm,
While the Amsoil is a hydraulic fluid, I don't know that it tells you anything about its suitability for aircraft brakes. Things like compatibility with seals, flash point, viscosity vs temp range.
Given that the Royco 782 that is aircraft brake fluid, and is compatible with all other aircraft brake fluids, is within $1 of the same price for a quart, I question this diversion to non-aircraft fluid. When you leak some and need to top off at an FBO, will you know how 5606 that they have on hand will react with the Amsoil? TheMIL-PRF-83282D assures that the Royco will be compatible, only losing some of its higher flash point, if mixed.
I can't imagine why you would need rotors before you have a few thousand hours on the plane.
Kelly
> Dave Leikam
>> Dave Leikam
Posted: Tue Aug 07, 2012 6:05 am Post subject: leaking brake calipers |
I borrowed a caliper from a customer to get home from OSH under very
similar circumstances. I ordered a replacement and when it arrives
I'll compare it dimensionally to the faulty one. I tried a new o-ring
but it leaked just as bad. There's no evidence of significant scoring
or marks in the bore, so I guess the bore is just worn too large.
We'll see when the new one comes in.
I think the Viton o-rings and MIL-PRF-83282D are the way to go.
Dave Saylor
831-750-0284 CL
On Sat, Aug 4, 2012 at 8:30 PM, David Leikam <arplnplt(at)gmail.com> wrote:
Dave Leikam
