esalehto(at)yahoo.com Guest
Posted: Sun Aug 05, 2012 5:28 am Post subject: LED replacement bulbs for Whelen position lights? |
Hi,
Have you found direct replacements LED bulbs (green and red) for Whelen navigation lights? I have Whelen 600 installed.
Esa
Pulsar XP
Rotax 912
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
otto(at)otamat.com Guest
Posted: Sun Aug 05, 2012 10:01 am Post subject: LED replacement bulbs for Whelen position lights? |
Hi Esa,
Is it the standard 12V microlamp you want to replace in red and green housing?
regards
otto
Pulsar III
Rotax 914
On 05/08/2012 14:27, Esa Lehto wrote:
[quote] Hi,
Esa
Pulsar XP
Rotax 912
Posted: Mon Aug 06, 2012 4:34 am Post subject: LED replacement bulbs for Whelen position lights? |
Hi Otto,
It is 1157 (BAY15D Socket) with single contact. Yes those bulbs are used on red and green housings.
-Esa
To: pulsar-list(at)matronics.com
Sent: Sunday, August 5, 2012 11:00 AM
Subject: Re: LED replacement bulbs for Whelen position lights?
Hi Esa,
regards
otto
Pulsar III
Rotax 914
[quote] Hi,
Esa
Pulsar XP
Rotax 912
el=nofollow target=_blank>http://www.matronics.com/Navigator?Pulsar-List
Posted: Mon Aug 06, 2012 5:52 am Post subject: LED replacement bulbs for Whelen position lights? |
Hi Esa,
thanks, yes, I make these...
The bulb outside box is one being replaced. The bayonet pins are offset. There is ballast in each supply line. You can use existing wiring, only cut the positive going to the socket and wire in the ballast.
Technical Specifications:
Model OTA204
Bulb physical size as ML7512-12, Whelen, Grymes and usual fittings compatible
LED each individual power 5W
Life 50,000 hours
Weight 100g complete kit
DC power 12-15V 0.9A
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} b\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> 281 1 7560000 10692000 359410 259 261 257 276 262 279 1 0`````````````````````` 5 1 1 285 282 1 False 0 0 0 0 -1 304800 243 True 128 77 255 3175 3175 70 True True True True True 278 134217728 1 1 -9999996.000000 -9999996.000000 8 Empty 16711680 52479 26367 13421772 16737792 13382502 16777215 Bluebird <![if pub11]> <![endif]> <![endif]--> 22852860 22856760 (`(at)````````` 266 263 5 110178060 110181960 <![endif]--> <![endif]--> They cost £180.00 plus P&P
otto
Pulsar III
Rotax 914
[img]cid:part1.07050705.06090206(at)otamat.com[/img]
[img]cid:part2.07090306.06080403(at)otamat.com[/img]
This is what they look like now.
On 06/08/2012 13:33, Esa Lehto wrote:
| Quote: | Hi Otto,
-Esa
From: otto souta <otto(at)otamat.com> (otto(at)otamat.com)
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Hi Esa,
regards
otto
Pulsar III
Rotax 914
| Quote: | Hi,
Esa
Pulsar XP
Rotax 912
155.04 KB |
6442 Time(s) |
175.91 KB |
6442 Time(s) |
Posted: Mon Aug 06, 2012 6:34 am Post subject: LED replacement bulbs for Whelen position lights? |
Hi,
Thanks Otto for your reply! I am looking for drop in type of replacement bulb without any modification. Yours look defenately good option when building new or when modifying the plane. I just finished repainting wings so I dont want to make any cutting.
-Esa
Sent: Monday, August 6, 2012 6:51 AM
Hi Esa,
Model OTA204
Life 50,000 hours
otto
Pulsar III
Rotax 914
[img]cid:1.267051757(at)web162805.mail.bf1.yahoo.com[/img]
[img]cid:2.267051757(at)web162805.mail.bf1.yahoo.com[/img]
| Quote: | Hi Otto,
-Esa
From: otto souta mailto:otto(at)otamat.com (otto(at)otamat.com)
Hi Esa,
regards
otto
Pulsar III
Rotax 914
| Quote: | Hi,
Esa
Pulsar XP
Rotax 912
155.04 KB |
6442 Time(s) |
175.91 KB |
6442 Time(s) |
kulpa(at)att.net Guest
Posted: Mon Aug 06, 2012 6:53 am Post subject: LED replacement bulbs for Whelen position lights? |
Take a look at this web site. I have these for my truck, they work great.
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Ftail-brake-turn.html
Best Regards, Bill
Cell: 512-415-2991
Home: 512-261-6375
To: "pulsar-list(at)matronics.com" <pulsar-list(at)matronics.com>
Sent: Mon, August 6, 2012 7:34:41 AM
Hi Otto,
-Esa
Hi Esa,
regards
otto
Pulsar III
Rotax 914
[quote] Hi,
Esa
Pulsar XP
Rotax 912
Posted: Mon Aug 06, 2012 7:31 am Post subject: LED replacement bulbs for Whelen position lights? |
